Melling oil pumps - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-30-2014, 03:17 PM
ericnova72's Avatar
More for Less Racer
Loc-tite on cover bolts does the trick.
Pump clearances are checked with feeler gauges.
I have no idea on the thin pump issue, as I have about 4 of the old style left, bought years ago, and haven't used them up yet.
I have seen links posted on other race forums to the Milodon pump, that they currently sell, and it is a heavy casting.
  #32 (permalink)
Old 04-30-2014, 03:28 PM
sqeezeit's Avatar
I would use what I have already which is 7qt pan and matching pickup but don't know if that's when used with standard size pump I'm guessing so that's what got me looking to begin with, plus I figured 3/4" pickup might not matter but it shouldn't hurt either. But at same time if I get other pickups there not cheap.Now trying to get and decide on pumps. I figured checking clearance with feelers but how?
  #33 (permalink)
Old 04-30-2014, 09:41 PM
awsomeears's Avatar
Precision Oil Pumps
You know for a extra $60 bucks that's great for peace of mind
$99 for a gone through M55
  #34 (permalink)
Old 04-30-2014, 10:21 PM
sqeezeit's Avatar
Originally Posted by awsomeears View Post
Precision Oil Pumps
Yes sir,but I have no issue with buying one.But if the castings are not thin/weak anymore like sum say then why buy a $100 one if a $50 one works just as good for the most part.Just trying to find ones that arent and since there can be boxes of old thin ones still out there I wont know it until I recieve it or someone opens box for me to confirm it before I buy.I have none to look at before purchase myself.It really is frustrating not being able to go to store and look at.
  #35 (permalink)
Old 04-30-2014, 10:23 PM
sqeezeit's Avatar
thinking about the milodon 18740, anyone have any insight on these.There suppose to be stronger then the mellings before they went thin?
  #36 (permalink)
Old 04-30-2014, 10:30 PM
awsomeears's Avatar
Heck, just call up your local store make sure they have a few in stock and tell them to bring them out. open them up who care
Check out the pictures here and then check out your local store http://www.paradisecruisers.com/SMF/...p?topic=6373.0
  #37 (permalink)
Old 04-30-2014, 10:53 PM
sqeezeit's Avatar
I know what they look like and what they did. I will check locals when I get home in a week,but having a feeling that there wont be to many to look at, if I remmember the last time I did some looking hardly anyone had any,will see
  #38 (permalink)
Old 05-01-2014, 10:02 AM
awsomeears's Avatar
I just spoke with a Tech george from melling and he said " The standard M55 is the thing model started in 2004 " and if I want the " THICK " casting purchase the M55A
And the spring installed " Pink " i believe is the 78lbs spring and if I wanted the pressures of the standard M55 just swap in the extra spring included in the box.
He called it there " Z28 " oil pump
http://www.summitracing.com/parts/mel-m55a/overview/
  #39 (permalink)
Old 05-01-2014, 10:56 AM
Lil Joe
oil pumps
After reading about all the troubles with melling pumps why wouldn't one just buy a milodon pump? They have all the accessories including oilpans. Lil Joe
  #40 (permalink)
Old 05-02-2014, 06:52 PM
ericnova72's Avatar
More for Less Racer
You remove the cover bolts, slide the cover to one side, and use it as a "straight edge" to check clearance between the cover and the top of the gears using feeler gauges. Too little clearance, sand the ends of the gears on a flat surface ...too much clearance, sand the pump main body where the cover bolts on
The Following User Says Thank You to ericnova72 For This Useful Post:
sqeezeit (05-02-2014)
  #41 (permalink)
Old 05-02-2014, 11:13 PM
sqeezeit's Avatar
Thanks for checking,I to just confirmed that only ones being done good again are the M55A.
  #42 (permalink)
Old 05-02-2014, 11:15 PM
sqeezeit's Avatar
Im thinking about it,especially for half the money of the select series.
  #43 (permalink)
Old 05-02-2014, 11:22 PM
sqeezeit's Avatar
What kinda clearances we talking,I have no idea,.001-.005? Thanks
  #44 (permalink)
Old 05-02-2014, 11:42 PM
ericnova72's Avatar
More for Less Racer
.0025"-.0035" was the often quoted ideal spec, Lingenfelter Racing says, .0025-.0033". Check the gears for burrs first, by running them across a flat surface backed 220 grit paper, then wash and measure.
  #45 (permalink)
Old 05-02-2014, 11:45 PM
sqeezeit's Avatar
Hey thanks for taking the time, appreciate it.
Melling oil pumps.? 65 f-100 restore Engine 11 03-30-2014 05:46 AM
Melling oil pump issue Studebaker Engine 14 07-11-2010 10:42 AM
Melling M155HV Oil pump? mrdreex Engine 34 06-26-2010 07:18 PM
new melling oil pump BBstroker Engine 3 05-26-2007 09:51 PM
Melling oil pump question??? Blown72Camaro Engine 1 05-20-2004 07:53 PM
