Hi I just started another SBC 383 build to day,its for fast road use and some light competition , this time in a volve 240 . So my question is which Melling select oil pump should I use ,as I was unsure which one to use ,and with the distance from me to Summit, I bought a selection of oil pumps, even a standard m55.The Select are 10522 and 10522 C. What attracted me to these pumps was the pick up (Canton20-021) bolts on and is designed to suit the Canton oil pan. ( 15-T 242 is that part number),So The pick up clearence is manufactured for me,
So which pump would be best for fairly high RPM and occasional Competition use 10552 10552 C or even the M55 for which I also have a press fit pick up.?Secondly . does it matter if these pumps have PM gears or steel gears ?. Somestimes the internet can confuse things with too much information , which is what I got when I Googled the subject.Ok my engine building shed is not nascar standards LOL. But its dry and clean
