Mellings Oil Pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2007, 08:02 PM
Mellings Oil Pump
After the posts concerning the Mellings oil pump and solid motor mounts I decided to change my pump to the Select series. I looked at the M-55 stock pump and what a POS.. I can see why it would break.. Anyway I ordered the pump from my friends machine shop and it came in and I always pull them appart and check and clean.. Well one of the cap screws looked like it was loose so I took it out and the head was almost broke off.. I finished breaking it with my hands.. The screws look like they are cast.. Real cheap.. So I wrote Mellings and told them of the problems.. They overnighted me a new pump here to my house.. Same cheap screws so I went and got some grade 8 6mm screws with locks and put it in.. I have some "REAL" good oil pressure now.. I think they must put a little bit tighter spring in the relief.. Anyone else seen these cheap looking screws??
Mitch
Old 04-11-2007, 11:36 PM
BLAZERMAN's Avatar
I have had no problems with Melling. I put a high volume pump on my 350 4 years ago .
Old 04-12-2007, 03:13 AM
Guy Hiltz's Avatar
Mellings Oil Pump
I just bought a new Select series for my big block and I was real impressed with it,took it apart for a look and all was good,the cap screw bolts looked to be a quality peice.
Old 04-12-2007, 09:04 AM
These dont look like high quality bolts to me..
Mitch
Old 04-12-2007, 09:10 AM
put a stock melling pump in most everything i build. Pump comes out of the box, gets taken apart & "massaged" and reassembled. Never had a problem.
Old 04-12-2007, 09:42 AM
DoubleVision's Avatar
Same here, been using melling oil pumps for 20 years, no problems as of yet. Those sure aren`t the same cap screws that we used in any pumps I bought.
Old 04-12-2007, 10:10 AM
Jmark's Avatar
I"ve used the stock M-55 pump in my last 4 engines and consistantly get 50+ pounds out of the box. Never seen a bolt like that before either!
Old 04-12-2007, 10:18 AM
King of my Man-cave.
I am holding a Melling 10552 pump in my hands as I write this. It has the same bolts as are in the pic. You can bet your sweet bippy that I am going to check the bolts and everything else VERY carefully!
tom
Old 04-12-2007, 11:05 AM
After I received the new pump I put the old one back together and was using a 1/4 ratchet and allen socket and snapped another head off. The bolts look to be cast...
tom
Old 04-12-2007, 01:17 PM
Mustangsaly's Avatar
I copied and pasted this from another site, but I think melling oil pumps have had some trouble.
got this from a Camaro site I still visit. First I heard of this. I don't know if any of you have picked up on this but it has to do with a change Melling made in their oil pump castings and it sounds like the weaker castings may have some problems.
http://www.nastyz28.com/forum/showthread.php?t=65870
Old 04-12-2007, 01:33 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
it seems to be a legit problem... any changes on melling's other oil pump applications?
Old 04-12-2007, 01:58 PM
Melling recommends to use the M-Select oil pump
moroso recommends using pumps p/n 22138, and 22139
melling makes morso pumps
Old 04-13-2007, 04:06 PM
Thanks for the heads up! Any one know when they made the change? I really don't want to pull my oil pan to find out if I got the new casting.
Thanks
Jordon
Old 04-13-2007, 04:49 PM
I'm going to start installing better bolts on the pumps I sell (and use).
I have an original oil pump from a 1969 327. The casting is practically identical to the newer, weaker casting. Apparently they beefed up the casting sometime after that, but some bean-counter or genius engineer decided that was too good of an idea so they went back to the original, weaker design......
tom
Old 04-14-2007, 05:24 PM
Guy Hiltz's Avatar
Mellings Oil Pump
Well ,looks aside, after reading what everyone here has to say about these bolts,I think that maybe I will change mine before I actually put it in my soon to be rebuilt motor.Theres always enough to worry about,I dont want my oil pump to be one of them !!!
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 05:03 AM
sbc oil pump drive nettio Engine 2 02-02-2006 03:19 AM
high volume oil pump question jstaten Engine 4 01-15-2006 11:56 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
distributor gear / oil pump wear ?? help bskaggs Engine 9 05-04-2004 09:55 AM
