Mercury 135 outboard stalling out. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2011, 01:27 PM
cboy's Avatar
Last journal entry: Finished
My Merc 135 outboard has developed a new problem. The symptoms:
* Will be running fine at mid to high speeds and then will suddenly stall out and die.
* After pumping the fuel line bulb a time or two, the engine will start right back up and run fine. But will then stall out again at speed.
* Engine will keep running at speed if my wife is at the throttle and I keep the bulb pumped up manually.
* There is fresh fuel in the tank which has also been treated with a bottle of Heet.
My diagnosis...the fuel pump is going out (or gone already). Any other possibilities before I buy the part and replace?
Always learning...and sharing what I've learned.
Old 09-25-2011, 01:57 PM
Joe G's Avatar
Maybe a fuel tank venting problem?
Old 09-25-2011, 02:29 PM
327NUT's Avatar
I've got a Merc 175 Pro Xs on my 24 ft. tri-toon fishing rig. I've been using "Don's Cocktail since brand new and never had a problem.......so, go to www.bassboatcentral.com (may have to join to ask a question) then click "BBC boards", scroll way down to the outboard engine section and click on "Mercury 3 ltr. high perf" (I know yours is a 2.5...no problem) then click on "General product info and maintenance" scroll down a bit to "commonly asked questions" (we're gettin there) then scroll down 5 lines to "Oil, battery, spark plugs, fuel and fuel additives.......and then read......wheww!
Now Don Weed is the Moderator of that section , runs a dealership in So. Carolina...I think and is a genuine great guy and a whiz with Mercury engines. His "Cocktail is a mixture of three additives ...these are all added per 6 gals of gas, 1 oz. Merc Quickleen....1 oz. Seafoam....1 oz. Merc Quickcare or Marine Stabil.
I have a fishing buddy that has a 135 Merc Optimax that was running like chit, first time he used the "Cocktail" his problem disappeared. You may have a different problem, bad fuel filter, plugged line etc. You can ask a question on the forum and Don will get to you in no time at all, hope this helps and solves your problem.......Dave
ID:	58579   Click image for larger version
557 hp LSA 6.2 ltr V-8 OUTBOARD engine!!!!! 327NUT Hotrodders' Lounge 8 02-22-2011 08:43 PM
Outboard casing Les Parker General Rodding Tech 1 09-17-2009 07:50 AM
40 Mercury Outboard Question 400smb_s10 Engine 11 06-28-2007 04:45 AM
outboard blues woodmanscott@hotmail Off-Topic 3 03-30-2006 05:22 PM
Non Hot Rod related outboard question Gearhead forever General Rodding Tech 1 08-08-2004 08:06 PM
