Metal 2 Metal on Zero Rusted Floor Pan Bottoms? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2007, 10:52 AM
Last journal entry: 1978 Mercury Cougar Xr7 Cruiser Project
So I have my floors welded in, and I have a seam on the bottom side.. My thought was this
Piclex 20 entire bottom side (stripped clean to bare metal)
tack weld every few inches along the way
grind those welds flat
Zero Rust the entire bottom side in and out of the seams
fill the seam I have (tight seam) with metal 2 metal on the bottom side over the ZR to get smooth
Zero Rust again
Will Zero Rust take the metal 2 metal, and is this just a bad idea alltogether? should I just use seam sealer over the floor bottoms?
I guess you could say I'm doing a "frame off driver".
Old 06-23-2007, 01:01 AM
Metal Twister's Avatar
Change is Opportunity!
Last journal entry: One More Seat
Zero Rust again
I was going to give you some advice with your floors, then I saw you were in MA. I just have a feeling its probably not as big of deal here in So. CAL. so good luck. I never salt proofed a car. LOL
Maybe Rhino line it?
Old 06-24-2007, 03:05 PM
LOL.. It won't see winter use, but will see 3 season rain included use.
Old 06-24-2007, 03:51 PM
Are the seams overlapped so water can get in them? If you can tilt your body this might work. When I lived in Ma. (26 years ago) my boss showed me how to take the welding torch and use the O-2 knob as a mini cutting torch to cut off the over lapped sheet metal back to the weld. Depending how much the customer could afford they woud stay unfinished, bondoed or leaded. We always used the sandblaster, metal prep, and Dupont Variprime. What is Zerorust, is Metal to Metal a dtm paint or bondo? Wurth USA sells the European undercoat that is industrial wax based. It is soft and reflows when it gets warm out. It is a yellowish clear color. I saw a Jetta that spent 8 years in Boston not a nut or bolt on the engine or suspension was useable due to corrosion but the body was perfect. Wurth also sells the european style seam sealer.
Old 06-24-2007, 08:53 PM
Zero Rust is similar to POR15.. search here on it..
Same with Metal to Metal.. it's basically a waterproof metal-laden body filler.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
Metal Finishing, let's talk about it. MARTINSR Body - Exterior 29 04-19-2011 09:47 PM
"Basics of Basics" Molding repair / metal finishing MARTINSR Body - Exterior 6 07-09-2009 10:47 AM
How do I work with old rusted metal? Arrowhead Body - Exterior 3 07-22-2006 11:56 PM
Metal Finishing, to quote the great philosopher NIKE, “Just do it”. MARTINSR Body - Exterior 17 12-24-2005 12:08 PM
