Metal chips in oil Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2010, 04:19 PM
E.T. divided by $ spent= Speed
So I try to change the oil in my daily driver,its a 99 plymouth neon w/ 2.0 sohc. Anyways as allways when I attempt anything on a newer car I get a disaster.
So the threads came out of the aluminum pan on the drain plug. I bought an oversized plug which leaked like a siv.So this time I bought the screw type w/ the butterfly nut that goes in the pan.Anyways in the drain oil I found a ton of chips of metal from the threads.If there is some metal in the oil in the bottum of the pan will the filter pick it up??
Pulling the pan is way beyond my capabilities and patience,for a FWD newer car.
Old 09-01-2010, 04:29 PM
ericnova72's Avatar
More for Less Racer
Buy a couple extra quarts of cheap oil, or some kerosene, to pour into the motor to use as a flush. Don't run the engine, just loosely install the drain plug and pour in the flush, then drain it. Best you can do without removing the pan, filter should catch the rest if there is any.
Old 09-01-2010, 04:39 PM
Cool, Thanks I hope so,I hate working on this car.Everytime I've taken a wrench to it something turns into an ordeal.
Oil change nuisances Slipangle Hotrodders' Lounge 13 10-09-2009 03:32 AM
cash for clunkers RONNYinWAXHAW Hotrodders' Lounge 105 08-20-2009 05:58 PM
Is it no good to have a High volume oil pump? Calderone Engine 17 01-31-2008 05:26 PM
preserve bare sanded metal with oil untill paint-day ? ManxCommando Body - Exterior 7 11-21-2004 09:54 AM
Oil Preshure ve3ham Engine 9 10-28-2004 02:36 PM
