Metal Etch Better than Self-Etch Primer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2003, 07:44 AM
unstable's Avatar
Murderator
Last journal entry: Brackets, Stories and the future
Post Metal Etch Better than Self-Etch Primer?
Any advantage to using metal etch, then primer...or just use self-etching primer?
Manual I have says to use metal etch, but what does the manual know? I have yet to see a manual paint a car.
Old 03-11-2003, 01:08 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
I use the metal prep liquid (etches and leaves zinc phosphate coating) and then prime with acid etching primer but then I wear a belt and suspenders with my suit so I may be too cautious.
Old 03-12-2003, 06:29 AM
unstable's Avatar
Murderator
Post
Good 'nuff for willys, good 'nuff for me.
Anyone else have input on this? Knowledge is la power.
Old 03-13-2003, 01:16 PM
bullheimer's Avatar
NEVER use credit cards!
Post
dont think it matters much. neither one will keep water out tho so paint asap unless you have red oxide primer. a guy at my paint shop i use sprayed this etching primer that is brown in color on his wheel wells over a year ago and he is bragging how great it is. i dont know the product however. he says its just etching primer
Old 03-14-2003, 12:04 PM
Don Meyer's Avatar
Post
I use Ospho(phos acid),wait 48 hrs & prime w/a epoxy primer(DP-40)....Don
