metal hex shaft in oil pan (5.0)?
Attempting to replace a truck pan and oil pump pickup with a mustang pan and pickup. While pulling old pan I found an intermediate shaft loose and in the bottom of the pan. This motor was previously rebuilt before I owned it.
with full view of the pump I see another shaft already in place. Are there two shafts for this setup? Am I missing where this additional shaft goes? Is there the possibility it was dropped on a rebuild and replaced leaving the dropped shaft in the pan and can discard it? Completely baffled. |
Yeah. when you pull the dizzy out to replace the pickup coil the pump drive shaft falls into the pan as the little retainer that keeps it in place breaks somewhere along the line.I have had it happen once or twice. Its kinda unavoidable whe the little clip is broken or MIA.
This is a common thing with SB Fords.
I do hope that you are replacing that oil pump and drive shaft with new ones. A standard volume oil pump and an MSD or Ford Performance drive shaft are very inexpensive when it comes to an engines longevity. I like these better then the Ford: http://www.summitracing.com/parts/ARP-154-7904/ and http://www.summitracing.com/parts/MEL-M68/ Dave W |
Dave W |
| Short shaft on long shaft tranny | sooper | Transmission - Rearend | 2 | 07-07-2010 04:14 PM |
| Question on 700r4 transmission tail shaft and front shaft | eric32 | Transmission - Rearend | 11 | 05-10-2009 12:03 PM |
| rusty metal primer on clean metal, pine trees and brawling | Stroke | Body - Exterior | 3 | 06-01-2008 07:29 PM |
| HELP! very stange metal on metal upper bushings on a chevelle, is this factory? | younguyw/oldcrap | Suspension - Brakes - Steering | 3 | 05-30-2004 05:17 AM |
| Changing T350 short shaft to long shaft | Jmark | Transmission - Rearend | 6 | 01-17-2004 04:22 PM |
