Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Metal Lathe for Hobbyists: Buying Tips and Recommendations
Old 07-25-2011, 05:59 PM
JohnnyK81 JohnnyK81 is offline
We have an older Taiwanese lathe that is IDENTICAL to this Jet
I think it's a good size if you have room (13x40).
And since it's not a Jet, I can only assume many other manufacturers made this exact same lathe.
However, since the times have changed, it's probably worth your while to get one that doesn't involve moving a belt to change speeds!
