Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is metal in the oil filter a bad thing? :(
Old 09-10-2004, 11:35 AM
orangef4 orangef4 is offline
I was going to say turbo until I saw the pictures.... I disassembled a junkyard turbo I had when building my setup. I had planned on using it, so I took it apart to check out the internals. The shaft bearings were fine, but the the thrust bearing was shot. It had nearly1/16" endplay. It should have been barely detectable. I did some checking, and it isn't too expensive to get them rebuilt. If you have to pull everything else apart, it wouldn't hurt to check. With that much metal, I would guess it is the cam.
