Metal prep before applying epoxy primer on Frame - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-25-2013, 04:53 AM
deadbodyman's Avatar
Wiki Edits: 11
Thats cool ...It sounded like some kind of mirical rust treatment...
That trucks been done a while hows that Por-15 holding up???
  #17 (permalink)
Old 05-25-2013, 08:16 AM
Originally Posted by deadbodyman View Post
I'm a big ospho user and I've done frames with ospho and a big wire wheel ,all I gotta say is holly crap thats a lot of work theres no way I'll do it like that again...
SAND BLAST that frame or(better yet) Have someone blast that frame, as cheap as I am THATS the one thing I'll gladly pay someone to do the job comes out SO much better...
When the frame comes back Then you can use ospho if you want , it'll help keep any surface rust off the frame plus if theres any small amounts of rust still in there it'll remove it and stop it from getting any worse ...it'll give you plenty of time to properly prep the frame for epoxy ...
although I wont blast sheetmetal, blasting the thicker stuff is always what I would do...its so much easier and faster...and it does a better job...
I am with you Mike, I am on a very tight budget and I am very cheap to boot, and on top of that I want to do everything I can because I love doing it. But sandblasting my frame, NO WAY BABY. I just called the place yesterday to find out how much it costs (they were closed so I don't have a number yet). I am working that number into my budget just like buying parts or materials, it is just part of the cost of building a car.
  #18 (permalink)
Old 05-25-2013, 10:34 AM
Pats55's Avatar
Sandblasting is the way to go on a frame, if you got the money, next best trick grinders and wire wheels ,Follow it up with Ospho, RustMort or Master coat rust remover and prep. Top it off with two coats of the moisture cured silver primer followed by AG 111 NYC anti-graffiti paint.this system is used a lot on bridges and offers many years of service life . Complete chassis kit is 69 bucks includes primer ,paint with hardner and solvent so it doesn't break the bank.
  #19 (permalink)
Old 05-25-2013, 01:39 PM
ogre's Avatar
the 'Duracell Project'
mirical rust treatment... lol. painfully slow rust treatment is more like it.
i tried it on a body panel just to see. 5 min later i had a clean strip 1/2'' wide and 2'' long
por15 is doing well. i didn't top coat it but it never sees the sun under there
it seems to be durable, i like it for brush on, flow out finish
and the fact you can touch up when you drill a hole or weld on a missed bracket
  #20 (permalink)
Old 08-30-2013, 08:52 AM
Mustang RUSToration & Peforman
OK, been using products like these for over 30 years. I like to same money as well. No reason to buy name brand rust/metal etches. YOu can get phosphoric acid materials at your local box store. They sell them sometimes under concrete cleaners. You will save lots, promise. I wipe the acid off with a paper towel. I induce no water into this equation. Wipe it off before it has a chance to dry. If it dries, wet it again and work it around, then remove with paper towels. Not fan of POR, but do like the Master Series as a base. If you have POR and want to use it, use it as a top coat on top of MS. MS has a line that is awesome, the AG111 for a topcoat. But use whatever top coat you like over the silver MS primer. For whatever it'sa worth, I am a user of epoxy. I use epoxy so much that some jobs are exclusively done with epoxy primer,. But if the metal is rusted, I use MS first, then my epoxy and normal materials.
The Following User Says Thank You to PetesPonies For This Useful Post:
desotolewis (02-18-2014)
Metal Prep and Epoxy Primer.... No so fast ! outoftouch Body - Exterior 38 03-26-2011 05:53 AM
Metal prep prior to epoxy Dan O. Body - Exterior 1 05-17-2008 03:46 AM
What grit do you sand epoxy primer before applying filler hemi43 Body - Exterior 8 01-24-2006 06:45 AM
metal prep and epoxy primer? 62galaxiguy Body - Exterior 6 05-16-2005 07:02 PM
Applying epoxy primer on bare metal? FrankR Body - Exterior 25 04-17-2005 06:16 PM
