Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Metal Prep / Conditioner vs. Self Etching Primer
Old 05-11-2013, 03:56 PM
TucsonJay's Avatar
TucsonJay TucsonJay is online now
I've been using metal prep (phosphoric acid) since the early seventies with zero issues. It simply changes iron oxide (rust) to iron phosphate... which is a dead gray material that is not in an "ongoing process", like rust is. It also acts as a mild degreaser.
If you pay attention, you can actually watch the rust turn from orange to gray. If a spot is tubborn, just scotchbrite it and wet-and-wipe again with prep.
I like R-Ms 801 prep, which contains alcohol, and does not require rinsing. Just wet it good... let it sit for a moment... and wipe it away. 30-60 minutes later you can paint. ....and you aren't spending unnecessary dollars on primer and labor.
Not everything being sold is necessarily a better idea. Metal prep has been working for around a hundred years.
