Metal Prep / Conditioner vs. Self Etching Primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2013, 07:58 AM
I have a bike tank that I am painting and on it's edges I have some chips down to metal. Otherwise the factory paint is mint. Of course my first thought was that I have to use a self etching primer which bent me because I had to buy more. Then I remembered I had some metal prep/conditioner that I was using to keep some aluminum from corroding after some restoration work I was doing.
My question is, bike tank paint aside, if I have a bare piece of mild steel whether it be a fender or anything else, is it ok, not ok, or "at my own risk" to use the metal conditioner/prep which is basically a very mild type of acid (what type I'm not sure. Maybe phosphate?) and then a primer/sealer or primer filler, instead of using a self etching primer on said bare metal? Of course all other preparations before paint being completed.
Thanks for the knowledge transfer.
Old 05-11-2013, 08:39 AM
put up or shut up
metal prep to epoxy is better than a self etching primer in my opinion.
Old 05-11-2013, 02:56 PM
TucsonJay's Avatar
I've been using metal prep (phosphoric acid) since the early seventies with zero issues. It simply changes iron oxide (rust) to iron phosphate... which is a dead gray material that is not in an "ongoing process", like rust is. It also acts as a mild degreaser.
If you pay attention, you can actually watch the rust turn from orange to gray. If a spot is tubborn, just scotchbrite it and wet-and-wipe again with prep.
I like R-Ms 801 prep, which contains alcohol, and does not require rinsing. Just wet it good... let it sit for a moment... and wipe it away. 30-60 minutes later you can paint. ....and you aren't spending unnecessary dollars on primer and labor.
Not everything being sold is necessarily a better idea. Metal prep has been working for around a hundred years.
Old 05-11-2013, 07:50 PM
Normally steel and aluminum would require two different types of conditioner.
Old 05-12-2013, 07:24 AM
Old Fool's Avatar
I stopped using metal prep a few years ago when I discovered SPI epoxy. Now I just sand with 80g or blast the rust away, clean with w&g remover and shoot 2 coats of SPI epoxy directly to the metal whether it is alum or steel .
Less products to buy, less products to misuse, and results are awesome.
Old 05-12-2013, 04:16 PM
Pats55's Avatar
30 years using Metal Prep never a problem either
Old 05-13-2013, 10:04 AM
BarryK's Avatar
Exactly!
Both PPG and Dupont have an excellent metal prep process, if you follow their instructions to a tee, if not good luck.
The Following User Says Thank You to BarryK For This Useful Post:
DLT (05-15-2013)
Old 05-15-2013, 05:36 AM
deadbodyman's Avatar
Wiki Edits: 11
X-2 ,metal prep to epoxy,,,,also back when I did use etch primer (duponts variprime) filler didnt stick to it very well...
Metal Prep and Epoxy Primer.... No so fast ! outoftouch Body - Exterior 38 03-26-2011 05:53 AM
epoxy or etching primer over bare metal? pineknot Body - Exterior 21 03-16-2007 07:53 PM
can i spray epoxy primer over etching primer without sanding? wickiewicked240z Body - Exterior 1 08-29-2006 09:07 PM
metal prep and epoxy primer? 62galaxiguy Body - Exterior 6 05-16-2005 07:02 PM
Epoxy -vs- Etching primer over bare metal? myfamiliacc Body - Exterior 7 03-22-2005 08:47 AM
