Metal Thickness
Hi
I am in the process of smoothing my door handles off,my question is what thickness metal should i use?Someone recommended 22 guage??? Is 0.8mm thick alright??It is brushed steel is this still alright?? Thanks Chris |
What make model and year of car are you working on?
If you are just covering up a recessed "hole" in a door like an 80ish Toyota pickup, guage matching isn't going to matter a lot if any. If you are butt welding in a patch, then the guage is much more critical. .08mm would be an eqivalant to 22 guage or .029 inch or so. Brian |
Well it isn't a hot rodder car,it is a Honda civic hatchback 94 model.
Seriously, the Civic metal is probably a little thinner than the older American stuff. Best to check it with a micrometer.
Ontario Rodders |
Your going to be filling in OVER a recessed area right? I can't remember or does it have a big rectangular hole? Than it isn't that big of a deal. But 22 guage is what that door is I am pretty sure.
If you have a nice close up photo it may help. If it is the handle I am thinking of it is a rectangular hole with a small lip. So, you will need to cut off the lip and butt weld the piece in. Or, you could flange the edge of the hole and lay the piece which is slightly larger than the hole into the flanged area and weld it that way. If it has the recessed area like a "dent" that the handle sits in you could leave it and weld a patch over the top. This is not the "best" way but could be done a little easier than cutting the area out and butt welding. I did it that way a number of times years ago on mini trucks. If you weld VERY slow with MANY tacks you can keep the heat down and not warp the door. Brian Last edited by MARTINSR; 10-23-2005 at 05:31 PM. |
cheers,i havn't taken the handle off yet but i think it is a whole there isn't a recess in the door where the handle is.
| Metal Finishing, let's talk about it. | MARTINSR | Body - Exterior | 29 | 04-19-2011 08:47 PM |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 29 | 06-18-2009 06:54 AM |
| Measuring sheet metal thickness? | sifua | Body - Exterior | 2 | 07-11-2004 11:28 PM |
| sheet metal thickness | servant70131 | Hotrodding Basics | 4 | 10-14-2003 06:04 AM |
| fender metal thickness OE vs. repro | mark2002 | Body - Exterior | 2 | 05-20-2003 06:37 PM |
