metal work - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2002, 10:21 AM
johnnymopar's Avatar
Love your nails! You must be a Libra
Talking metal work
Have a 20gauge panel that i welded some brackets to. This warped the panel a bit and i tried to grind it smooth. But now, marks are showing thru the paint. What is the best way to fix this?
Thanks,
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 04-22-2002, 06:58 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Post
If they are pretty good marks I would use body spot putty and block sand and then use a high solids filler primer and block sand again. You may have to prime and block sand twice. I got ahead of myself, Grind or sand your paint off down to metal first.
[ April 22, 2002: Message edited by: Henry Highrise ]</p>
Old 04-23-2002, 07:28 PM
Post
Something I use in the bodyshop is some stuff called evercoat metalglaze. Its a 2 part stuf like bondo it comes with hardener.It comes in a pint bottle.It flows out real good and sands easily with 180 grit.You can put it right over the paint , but scuff the paint with 180 or 220 first. That will give it something to stick to.Then smooth it out and primer.
Old 04-24-2002, 05:13 AM
Post
I agree with big dreams, you are going to need some kind of filler in there to fill in your marks and smoth your part out again. I would advise against using spot putty, it is just a thick form of lacquer primer which will shrink after time.
Old 04-24-2002, 11:03 AM
Post
Ya, i personally would go with a good quality two component putty . Spot putty shrinks after time.
Old 04-24-2002, 04:59 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
I use a product called Metal 2 Metal, its a two component puddy that contains aluminum, works good, a bit hard to sand, but it works
Old 04-24-2002, 07:27 PM
Smile
The metal glaze will do what you want it to do and will not shrink. It is also easy to work with.
Metal Fabrication book review. MARTINSR Body - Exterior 13 12-08-2013 12:00 PM
Rust, metal work, sanding, Paint!! 1970Chevy Body - Exterior 9 06-28-2007 08:00 AM
Nice metal Work.. ehsankiani Body - Exterior 2 07-06-2006 12:26 PM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 10:47 AM
my doors got stretched nomad57ry Body - Exterior 17 12-02-2004 07:51 AM
