Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Metallic Base/Clear Issue
Old 05-02-2012, 11:41 AM
johnyIROC johnyIROC is offline
Last journal entry: G8 GT 2
Originally Posted by mitmaks
Theres nothing wrong with non-hardened basecoat. You do have to follow instructions though and not rush it or else you'll mess up.
We talked to the local PPG rep, and he said to resolve the issue with it lifting the 2K clear on the feathered edge, I would need to add hardener to the MBX even though it is not called for. Without the hardener, even if you build up several dust coats, the first medium coat will saturate any base it is in contact with and keep lifting the clear. Without the hardener, the 1K is not an effective sovent barrier.
Shot it last night with the hardener and it worked like a dream. I am sure there are some people who can shoot MBX day in and day out with no issues, but for me the hardener makes the stuff a lot easier to work with especially if it is metallic.
This job is finally done. Thanks to all for the advice.
The Following User Says Thank You to johnyIROC For This Useful Post:
slapshot (12-05-2012)
