metallic base isuses - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2011, 06:49 PM
I am a automotive tech and i use a devilbiss gfg 670 with a 1.4 tip and the pressure i spray with is 40psi and and line pressure is 90 psi, and when i spay a coarse metallic color in basf glasurit on hood of cars i notice that the color is bloching on the hood any advice how to fix this.
Old 01-25-2011, 07:06 PM
Think of it this way.
When you mix the metallic paint, and let it sit in a cup, and do not stir it, the metal flakes settle to the bottom of the cup. The paint looks different from the top of the cup, to the bottom.
The same thing happens when you spray it on a panel. If you spray "wet" the flakes have more time to settle down, and look one way. If you spray "dry" the flakes pretty much stay the way they hit the panel, and cannot settle much. The paint looks different than the "wet" sprayed panel.
The cure, you have to be very consistent on how you spray the panel. The overlaps have to be exact. The gun angle has to be exact. The speed has to be exact. No fanning away from the panel at the end of the stroke. You need good light.
I have found sometimes I can make the panel look better by spraying the second coat 90 degrees to the first coat.
Old 01-25-2011, 07:48 PM
I do a drop coat to eliminate blotching... drop psi to 18-20 and back your gun distance... consistant overlaps and adequately aggetated paint with this technique ensures 95% of blotch issues are eliminated... at least in my experience... just beware of the blue poly interested to hear what the pros do tho?
Old 01-26-2011, 04:49 AM
deadbodyman's Avatar
Wiki Edits: 11
bloching and tiger strips ......if its not air pressure set to high or an uneven pattern from the gun,try spraying it a little drier..(move faster).the most common mistake I see is people spraying a base nice and even and shinny like a SS ...base should look dull and blochy when wet but nice and even when it dries.
I spray two coats then fog in a few X pattern coats and never get stripes even with the cheap stuff like Nason...
Quick question on scuffing metallic base before re-shoot Mycophiles Body - Exterior 4 07-18-2010 05:13 PM
Dummy Newb Q--Can I get metallic paint without the metallic? superkaz661 Body - Exterior 4 10-07-2008 04:16 PM
help with sanding metallic base Samsonian Body - Exterior 8 10-12-2007 12:24 PM
Need a good spray gun for spraying metallic base camaro freak Body - Exterior 1 04-18-2006 05:26 AM
Dupont Clear over metallic base dave220 Body - Exterior 5 04-01-2005 08:16 PM
