Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Metallic Paint Problem
Old 06-15-2003, 10:10 AM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Well, I am sort of lost on your post. If you used a different mix of paint than the original, there is little chance it will match perfectly in a metallic paint. If it is out of the same can, I would say you did not mix well enough in the can before mixing for spraying.
Chris
