Chris - the colors are the same on the frist spray as was the last spray - . What I was doing was repairing some wetsanding problems I had. Instead of completely sanding out the clear and base coat, I just sanded the surface clear with 400 grit and then sprayed base coat and clear over the "messed up" wet sanding job I did. The problem I ran into was the color not matching. Basically it was primer sealer/blue metallic base/clear/blue metallic base/clear.
