Metallick Colors help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2011, 10:23 PM
Scandinavian's Avatar
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
Hi Ive just Got the 34fot Wild Flowerpainted..First out ive used a Super Jet Black collor. and on it ivegot Darck black mettalick top coat and it is the black topcoatmettalickthat gives me some problems.. if i paint it Clowd free it stays a little drye and if a make it glossy it stayes Clowdy.. how to gett it wright with out Clearcoating??
its suposed to be like a Ghost flame the water lines and the flower.
http://finnflyer34custom.blogspot.co....html?spref=fb
Old 04-06-2011, 10:59 AM
Enybody?? some help pleas??
Old 05-07-2011, 03:43 AM
[QUOTE=Scandinavian]Enybody?? some help pleas??[/QUOG
Guess not.
Old 05-07-2011, 07:29 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
usually clouding is caused by trapped solvent in your paint try using a slower grade of reducer so it holds the top coat open longer.
Old 05-07-2011, 08:47 AM
Are you using a marine paint, or an automotive urethane?
Old 05-07-2011, 11:37 AM
Its a marine color. Alexseal
Old 05-07-2011, 08:52 PM
Alexseal is a very good marine paint, similiar to Awlgrip.
It's an LPU and those require a few days to fully cure.
Swvalcon is probably right about the trapped solvents
causing the cloudiness. Or it might be trapped humidity.
I would wait a couple more days and give the trapped
solvents or moisture time to evaporate out, and the
gloss to come back.
Old 05-07-2011, 10:41 PM
gloss to come back.
Awlgrip is a pretty good color but im not a friend of the awlgrip`s ultrabuild it gets to hard and its a Nightmare to sand down.. okay it has gone a few weeks since I've painted the Wild Flower boat butt it is still the same way!? Humidity Wat Cinda humidity percentage do you have when you paint ower there??
University Colors Turdpolisher Body - Exterior 4 10-20-2010 06:16 PM
would like to see my car in different colors yragat Hot Rod Art 11 06-26-2010 08:56 PM
where to buy wire in many colors? matt167 Electrical 2 09-12-2009 06:15 PM
Is it possible to match single stage colors to 2 stage colors? STATUTORY GRAPE Body - Exterior 6 02-05-2006 11:32 AM
candy colors 38 old coupe Body - Exterior 8 07-05-2005 10:49 PM
