metalwork issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2013, 11:37 PM
metalwork issue
I seem to be stuck on this taillight and am a complete newbie, it needs a pretty deep flanged lip to recess the light trim into. the top is fine but the bottom half has been flattened from previous work and I need to re-create the lip. As you can see i tried to bend it best I could then use filler to build the lip up, but realized this wouldn't work well and chipped the filler away to try again. I bought a flanging gun but the die isn't deep enough. A friend of mine says I should make two small cuts in the lower corners and carefully put two bends into it with pliers or dollys then tack weld the corners back together. Just wondering if you have any ideas, I wish I could get a body guy over to do this bit for me, I'm worried it needs to be done right or will look akward forever.
Old 08-13-2013, 11:49 PM
put up or shut up
the recessed part in the back, just forget about keeping that flat and perfect while doing this for now. I might try a few different things but the first thing that comes to mind is that I'd bend that flat recessed area inwards and with a good sharp dolly I'd recreate the depth of that edge, borrowing metal from the flat recessed area, then with duckbill pliers bend it back flat. That seems like the only way but then again I'd sit there for a couple minutes like a caveman trying to fit it and looking for any little thing that it could be other than the depth, like perhaps the part is bent, one corner not allowing it drop, etc-etc.. THEN, I'd do that. A bead roller can also work and would be the better choice but I'm assuming you don't have one.
Old 08-14-2013, 02:13 AM
carolinacustoms's Avatar
Automotive Extraordinaire
From the looks of the picture, the whole rear half of the opening needs to be worked out using a hammer and dolly before the light will fit right (it looks like there is a bow/bend in the opening). If you have a friend that can help with holding a dolly on the outside while you work a hammer and maybe a bar/extension of some kind to get things worked a little closer on the quarter panel, (be sure to use something flat on the end) then work on the light recess area. As Tech stated, you can work the first inward bend of the recess in with a sharp dolly (or any piece of solid, sharp edged metal) and then bend the flange back up as needed with pliers, vise grips, etc then dolly everything out smooth.
Kelly
Old 08-14-2013, 08:14 AM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
Looks like the bumper took a hit and distorted the bezel area. You need to get all that filler off again and see where the material went for the recess. The whole area needs to be dollied back into shape before working on the recess.
You could also look for a donor cut out and just replace the entire bezel area AFTER the panel is re-shaped. What are you working on ? It bezel looks similar to a 68-72 GM truck but the bumper recess looks more like a 70-72 Chevelle.
The Following User Says Thank You to Too Many Projects For This Useful Post:
carolinacustoms (08-14-2013)
Old 08-14-2013, 08:26 AM
Banned
X2 on that, what car is it. With all that filler . you may find it easy to just buy a new panel and weld it in.
Old 08-14-2013, 10:47 AM
Could you just bend the bottom lip back and weld on a small vertical lip or tabs?
Old 08-14-2013, 11:35 AM
It is a 76 trans am
It does look like the rear took a small hit and the last person to repair and paint didnt fix it 100 percent.
The lower edge of both rear quarters needs replacing so i ordered those patch panels, but the new patch doesnt go as high as the light. I looked into getting a whole rear quarter and cutting off what i needed, but it was $300 and anything around here will probable be in worse shape than what i have. A repro quarter is probably expensive to buy and ship to canada and was told they dont fit as well as oem.
I have a couple other small patches to do today but will try the advice above asap.
Old 08-14-2013, 11:58 AM
here is before filler, you can see the narrow patch at the bottom and some bumps at the rear of the tail where it looks like maybe a puller was used.
here is after my filler work
Old 08-14-2013, 01:41 PM
My personal feeling is that I dislike the side marker lights anyway, so I'd just weld a patch over the whole opening and dispense with the issue entirely. But that's just me.
Old 08-14-2013, 02:36 PM
I also had that thought, car is going with a pro-touring look. I just hate to do something thats hard to reverse, would be nice to be able to easily put it back to orig.
Old 08-14-2013, 03:28 PM
Banned
contact this place, they maybe able to help. have alot of used parts
firebird sheet metal
Old 08-16-2013, 09:54 PM
That took more than a light hit. The panel is buckled forward of the marker hole too. It all needs to be pulled back more to relieve the buckles and dollied out around the marker hole. In reality, the last 3ft of the quarter should've been replaced with a donor.
Old 08-17-2013, 09:17 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Get a copy of this book and start tapping away with a hammer and dolly.
Key To Metal Bumping Book : Amazon.com : Automotive Key To Metal Bumping Book : Amazon.com : Automotive
Get yourself a shrinking disc as well.
Old 08-17-2013, 03:28 PM
Found some time the other day to work on it. Used an alum block and hammer to bend the lower half in and used pliers to bend the lip back. Definitaly not perfect but learned a bit. seems to fit way better than before. Tried to flatten out the whole panel a bit more best I could and then hit it with some epoxy. I might continue with filler now, I'm worried if I try to fix it more I will make it worse.
Old 08-17-2013, 04:19 PM
put up or shut up
that looks good! Now you just have to metal work what's around it. Don't feel bad, it never ends. Least now you have something on it to gauge after you block it. Straight edges are always good to so you can compare to the other side. I like to use it straght and then rock it around checking differences. It can tell you what the eyes, hands, and guide coat can't. Very good for quarters that were smacked hard, especially by the wheel crown.
Best 60s Issue of Hot Rod Magazine and best 50s Issue of Car Craft MXrider13 Hotrodders' Lounge 18 07-29-2011 02:55 PM
vacuum issue or carb issue idk for sure chevyok06 Engine 1 07-10-2011 06:19 PM
A/C issue ap0001 General Rodding Tech 3 05-20-2010 08:44 PM
10-12 Bolt U-joint Issue Issue MrB Transmission - Rearend 3 09-29-2007 09:17 AM
The next issue... draft Electrical 0 07-29-2004 06:27 PM
