metering valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2008, 03:49 PM
metering valve
I switched from a single to a dual port master cylinder on a drum/drum brake setup. Is a metering valve necessary for the front brakes? I have a residual valve inline for my rear brakes. Thanks
Old 02-09-2008, 06:00 PM
not needed, thanks anyway.
Old 02-10-2008, 08:00 PM
By a residual valve do you mean proportioning valve? Did you find out what a metering valve does? If I recall correctly it insures the rear brakes apply a few milliseconds before the front ones do. Therefore, you are correct about not needing one for the front brakes.
MP Brakes metering valve? Mental Block Suspension - Brakes - Steering 7 04-02-2013 10:15 AM
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 35 12-28-2006 10:11 AM
oil being sucked threw the pcv valve on my 350 sb.. Robbie Engine 23 05-08-2004 09:12 AM
question on hardened valve seats stfinney Engine 19 05-06-2003 06:46 AM
