Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Methods to control 700r4 converter lock up clutch ?
Old 08-29-2012, 06:13 AM
dogwater dogwater is offline
Last journal entry: Still running strong
If you have no voltage to the sol.valve then it shouldn't be locked up. Why it stalls in gear,I don't know.If you have normally open pressure swtichs or switch they will act like an open curcit. I don't know if you know that the pressure switches on 700r4 come with two kinds, n.o. & n.c.I compleatly rewired mine using n.o. 4th gear pressure sw. only & n.o. sol. valve,both are grounded to the case.Didn't use the heat sensor so its only one wire.
