Originally Posted by 52 mike
my trans is rebuilt and i've only put a couple miles on it, i shifts fine thru all gears, but when i stop the engine dies. like i said there are no switches hooked up to tc lock up plug. also curious there are 7 detents in my overdrive steering column out of a chevy van, but i count only 6 positions on my tranny when i hooked up shift linkage. shifter on column won't go into 1st gear.
P-R-N-O/D-3-2-1
If you can't get Low/1st your shifter Linkage isn't adjusted correctly & may be trying to go into 2 gears at once.
What Trans did the Chevy Van have in it?
