metric pipe threads?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2007, 02:05 PM
Hi
I there such a thing as metric pipe threads? what I want to do is use nissan gages with a chevy motor. Will the nissan oil & water senders screw into a chevy? If not where can I find adaptor fittings?
Old 10-25-2007, 05:42 PM
Originally Posted by yragat
Hi
Yes, there's a difference between US pipe threads and metric. The ISO metric specs adapted the British Standard Pipe thread series instead of NPT, and the thread pitches are slightly different. For example, 1/8 NPT has 27 TPI and metric has 28 TPI. Very close, but different. Adapters should be available from the gauge manufacturers.
Bob
Old 10-25-2007, 06:11 PM
Thank you very much.
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
trans cooler tomco550 Transmission - Rearend 1 10-06-2006 03:44 PM
Airlines Kevin45 Garage - Tools 22 03-04-2004 04:35 AM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 08:04 AM
