mexico suffix codes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2006, 11:00 PM
hello all
1st time poster, long time reader (well month or so, haha)
so, i got this engine givin to me , its a 350 chevy, 4 bolt main. casting # is "10066036"
but i can not find the suffix code any where on the web, the code is "M05280VP".
if anyone can help me on this one, that would just be killer.
thanx a mill,
poy41
Old 09-17-2006, 11:30 PM
327NUT's Avatar
Its a "made in Mexico" Target Master or Goodwrench crate engine, comes in either 2 or 4 bolt. Dont have a clue what the first series of numbers mean but if it has'nt been overbored it should work ok for a mild street engine. What do you plan on doing with it?
Old 09-18-2006, 12:12 AM
was thinkin of putting it into a S10 or something like that...
i just rebuild a 350 for my car (1970 lemans sport)
but i need something for the winter to play with.
poy41
Old 09-18-2006, 12:29 AM
327NUT's Avatar
OK the first thing I would do is take it to a good machine shop and have the block checked. If its rebuildable try to keep it around 9-9.5 to 1, a Comp Cams XE268H-10 cam.... 224/230 dur. and .477/480 lift and a 650 Holley, you really dont need more carb than that for the street, and if you are using the stock heads then thats all they can handle anyway, and it will give you better throttle response. It will have more grunt than that S-10 will ever be able to handle, especially the rear end. Lots of other ways to build it and I,m sure someone else will offer thier idea's.
Old 09-18-2006, 12:59 AM
thanx for your input man. i was going to take it to a machine shop this weekend but things came up.
but does anyone know what "M05280VP" suffix code means?
poy41
GM 5.7L crate engine suffix codes SCRUBBY Engine 2 11-30-2009 04:36 PM
suffix codes dave171 Engine 1 09-13-2006 11:42 PM
Check this out. Unknown Suffix codes (CZE) badams Engine 2 04-19-2006 09:01 PM
Engine suffix codes 67 Hugger Engine 3 06-02-2004 09:35 AM
where to find GM engine suffix codes? 327amc Engine 1 01-04-2004 01:12 AM
