-   -   mid 70's bottem end, 1990 top end, 90 water pump...overheating!!! (http://www.hotrodders.com/forum/mid-70s-bottem-end-1990-top-end-90-water-pump-171911.html)
erickmi 01-23-2010 09:57 PM
i've heard yay's and nay's about the way the wayer pump is spinning on the older style block being a newer style pump...could this be the reason it overhats and collapses the bottom hose
Chevrolet4x4s 01-23-2010 10:38 PM
What type of engine is it? You may be running a reverse rotation water pump standard direction,with the impller spinning the wrong direction it wont move much water at all.
Shane
airboat 01-23-2010 10:40 PM
Answered your own question. It's trying to pump water if it's collapsing the lower hose but you need a better lower hose or spring in it to prevent collapsing because a collapsed hose won't allow flow.
Rickracer 01-24-2010 08:31 AM
Agreed, the collapsed hose will cause overheating bigtime, and if it's sucking the bottom hose shut, chances are it's the correct rotation. :cool:
rockcruiser 01-24-2010 08:51 AM
Or Even a plugged radiator will cause the lower hose to flatten :thumbup:
