Hotrodders Bulletin Board
#2
The steering box won't work. '79 is the last year with a box that'll bolt into your truck. As for the column, keep in mind that Ford starting putting the ignition switch on the column in '80, so it's not going to be a 'Plug-n-Play' operation. You'll have to do a bunch of rewiring. It would be a lot of work considering that power steering columns for the '67-'72 Fords are very plentiful and a bolt-in. You can use a '73-'79 column and it would bolt in just fine, though there would be a couple wires you'd have to change around...nothing major.
Read this link: How to Install Power Steering in 2WD '67-'72 Ford Pickups - A complete tutorial on what parts you'll need and where to get them Hope this helps. |
Back to top |
Similar Threads for: "mid 80's power steering and column for 69"
| 56 Ford Victoria pwr. steering options? | murrsue | Suspension - Brakes - Steering | 18 | 02-05-2006 02:10 PM |
| Steering Column Harness on a G-body | 1982 SS | Electrical | 2 | 07-29-2005 01:06 PM |
| custom steering column | Blob | Suspension - Brakes - Steering | 5 | 07-08-2005 01:28 PM |
| '39 ford steering column and wheel | jim williams | Suspension - Brakes - Steering | 4 | 01-27-2004 07:28 PM |
| shortening the steering column | smoran | Interior | 3 | 05-02-2002 06:38 PM |
