mid eighties 350 TDC - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2008, 10:42 PM
Does anyone know of a mid eighties chevy 350 that had TDC at the 12 o'clock crank position when viewing the block from the front. The timing cover has the pointer at that position. When checking for TDC through #1 cylinder's spark plug hole it appears to be so. Any info is helpful.
Old 06-26-2008, 12:16 AM
Jmark's Avatar
Yes, there are many and I have two! LOL 86, 305 Caprice and 86, 3/4 ton truck, 350. It's a pain to see past all the vacuum hoses and crap but does work. You will also notice there is a tube built into the timing tab on the cover. That was used for a magetic sensor that most scopes had on them. It would read the timing without a light or even looking. The shop I was in had one and it was slick.
Old 06-26-2008, 03:45 AM
malc's Avatar
Living At The Speed Of Life
Be careful when buying a new damper................
Old 06-26-2008, 11:29 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Yeah I thought only 305's had the timing tab at the top but then i got into some 1980-1986 350's that had it there as well. I believe the 1987 and up are on the side though. As far as the balancer goes you just need the timing cover to match your balancer, most aftermarket covers don't have a tab at all and it is up to you to find TDC and mark it on the timing tab.
Old 06-27-2008, 03:08 AM
When you're stretched out trying to get your face and the timing light both behind the water pump at the same time, be sure the fan, etc., doesn't catch your shirt-tail. It almost got mine.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 07:22 AM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 12:39 PM
327 or 350 chevy (please no rookies) chris oswalt Engine 16 12-11-2004 09:29 PM
