Mid-length headers for 59-64 impala's? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2013, 11:42 AM
Motochris's Avatar
I put full length headers on my new engine build...and they suck as far as ground clearance goes. The car is fairly low and the headers are just way too low. I've got to change them out to something that doesn't hang under the car. Shorty's will obviously work, but I figure a mid-length would be better for performance. Haven't spotted any yet (other than for LS swaps), though I'll be searching around more today.
Anybody know of a set of mid-lengths for a SBC?
Old 10-03-2013, 11:57 AM
techinspector1's Avatar
Wiki Edits: 326
How about full-length fenderwell headers?
Old 10-03-2013, 12:45 PM
Motochris's Avatar
I haven't seen those either. Not to mention... if they involve pulling the fenderwell out, I wouldn't want to do that.
My current headers are the Hedman Elites. Really very nice, but they routed them too low. They could be about 1.5" higher than they are and still clear everything. Currently with two people in the car, the exhaust flange is between 2-3" off the ground. By far the lowest part of the car and sucks to be so watchful of everything.
No question.. I'll bash the hell out of these at some point. I figure it's better to replace them now while I can still sell them for something.
Old 10-03-2013, 12:48 PM
Wiki Edits: 326
My current headers are the Hedman Elites. Really very nice, but they routed them too low. They could be about 1.5" higher than they are and still clear everything. Currently with two people in the car, the header flange is between 2-3" off the ground. By far the lowest part of the car and sucks to be so watchful of everything.
Or....you could be resourceful and weld some 1/4" plate baffles off the frame structure to sit in front of the headers and defend them against bashing. I wouldn't let a little thing like ground clearance force me to get rid of a set of quality headers.
Old 10-03-2013, 12:52 PM
RWENUTS's Avatar
I have a set of these on my truck. I think they'll fit yours.
http://www.summitracing.com/int/part...del/c20-pickup
Old 10-03-2013, 12:58 PM
Motochris's Avatar
Your comment made me go out and actually measure. With nobody in the car... they are right at 2" off the ground. I'm gonna guess close to an inch or so with people in it.
"Little thing like ground clearance"....there's a limit to that.
Old 10-03-2013, 01:05 PM
RWENUTS's Avatar
And here's a pic or two!
Ceramic coated.
12 years old now!
ID:	86241   Click image for larger version
Old 10-03-2013, 01:08 PM
Banned
check the clearance around the headers and modify them, the mounting surface, or something else to raise them up a little.
Old 10-03-2013, 05:25 PM
Motochris's Avatar
I'm giving in for now, can't find anything that will work... ordered some shorty's. I plan to take the car to Gene Winfields on the 12th and don't want to drive it there with these headers on it. Don't think it'll make it without destroying them.
Old 10-03-2013, 08:46 PM
Last journal entry: New Rev wheels and BFG KDW II tires
I bet mine are close to the same as yours and I am running Hooker Super Comps. They could easily make them an inch or two higher if they had a person modify the inner fender which wouldn't be that hard to do. It sure would beat having them hang so low.
This is the first summer I've had the headers on the car. I've scraped them a couple of times and had one major impact only going a mile or two out of a parking lot that had a bad lip at the exit. Ouch! I didn't wreck anything but it didn't sound very good.
I'm thinking of making a new set of headers this winter out of stainless with a few modifications to make them fit better with more ground clearance. It shouldn't be too hard if I go bythe Super Comps that are on the car and adjust them to suite my needs.
Old 10-03-2013, 09:12 PM
GMCTRUCKS's Avatar
I seen some SS ones on ebay.
Old 10-04-2013, 05:12 PM
Motochris's Avatar
I was all over EBAY yesterday. Only midlength I saw were for the LS conversion.
I bought a set off ebay about 2pm...I already have them!
Who knows what I end up with eventually.... if I can't sell the full length ones for much, maybe I'll look at modifying them to fit.
Old 10-04-2013, 05:18 PM
Motochris's Avatar
I have to drive a mile of rocky dirt road each way to leave my house. That's my biggest issue. Just crawling thru sections trying not to screw the headers up. Just not worth the headache and potential issue of catching them on something far from home.
Old 10-04-2013, 05:41 PM
jokerZ71's Avatar
Wrench Turner
I tried to refind the article so I could post a link,but,no such luck.The article tested shortys,mid-length,& longtubes on a dyno.The shortys were the type that use stock exhaust hookups w/ 2 1/2" collector.The mid-length had a standard 3" 3 bolt header collector.I can't remember the actual gains from each offhand.Naturally the longtubes made a lot more torque & power,but,only @ higher RPMs.At lower RPMs there wasn't much difference.The type of shortys used really didn't make enuff difference to justify the costs & work to put them on @ any RPM .At higher RPMs,the mid-lengths made approx half the gains as the longtube. If I can find the article,I'll post a link.
Old 10-04-2013, 06:33 PM
I watched a youtube video where they tested long tubes versus the good rams horn and there was only about a ten horsepower difference if I remember correctly. And I believe the difference was only at about 5,000 and up.
spark plug length for headers-want ac delco one92rs Engine 1 03-28-2011 05:58 PM
Pipes for headers theory...same length? Slickriffs Hotrodding Basics 15 11-26-2007 10:02 AM
Mid Length Headers for Pickup Chevy21 Engine 4 09-04-2007 03:45 PM
Full length headers on hot rod? staleg Engine 3 12-29-2006 06:51 PM
Mid-Length Headers Koolaid Engine 5 11-01-2006 09:50 AM
