Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mid lift rockers
Old 10-22-2011, 05:36 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by millerrockers
The correct "symptom" that would be illustrated in the valve motion atop the valve tip would be A to B then back to A, there is no C. The roller sweeps out to its farthest point at precise "net" valve MID-LIFT, then rolls BACK to the inside of the valve as it reaches maximum net Valve Lift.
So, if following the mid-lift scenario, at max lift am I correct in thinking the roller should be at a position more towards the intake side of the valve tip as I originally thought?
BTW, the Comp diagram uses "1", "2" and "3" for the positions of the roller across the tip of the valve, not "A", "B" and "C". So is your "A" above = 1, "B"=2 and "C"=3?
Thanks for your time.
The Following User Says Thank You to cobalt327 For This Useful Post:
sweetlil66 (05-19-2013)
