Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mid rise lift hoists ?
Old 02-13-2013, 06:29 AM
streetrodderbn's Avatar
streetrodderbn streetrodderbn is offline
Certifiable Streetrodder
What do you mean by "mid rise lift"? Years ago I had a "Quicklift" that was basically a drive on ramp system. It lifted the car @ 2 ft. off the ground and you used a floor jack to lift the ramps to allow the drop down rear legs to lock them in place. This system is one of the few types for low ceiling height, It was well made, It worked ok, but you still have to crawl under the car to work on it! I think it would be fairly easy to use a set of wheel dollies to make the Quicklift portable,check the internet, they may even have a wheel kit now!
