MIG or Bronze..??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2010, 09:37 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
MIG or Bronze..???
I'm fixing some... actually a lot of body cancer on a Datsun 1.200 pickup truck ( I don't think you have them in USA.?) there's rust everywhere, I think I may need a tetanus shot..lol.
anyway the question is, I will replace all the body pannels and I'm wondering if brazing them would be a better idea than MIG welding, I ask this because this panels are soo thin that it's a real ***** to weld, even on the lowest setting of my Miller.
All body shops here don't use either method, they use regular gas welding, oxi-acetilene torch and steel filler rod.
What would you guy reccomend?
thanks.
Augusto.
Old 03-04-2010, 11:15 PM
kringold's Avatar
ATA Welding Technology
If you can, I'd use the Oxy-acetylene, otherwise you will have to use the MIG. If you use the mig for holes, what I do is start on the outside of the hole on good material. Run a short/fast bead around the hole to build up material, and let it cool. Then say another bead half way around on the inside of the last bead, let it cool, and so on. Take your time and keep it as cool as you can. As far as welding panels/sheet together I would chose the MIG and go slow and use stitch welds, always keeping it as cool as possible. You can use a cold wet rag on it or air from your compressor to help keep it cool.
Old 03-04-2010, 11:39 PM
Augusto,
you should be able to get 2" / 50mm long copper tubing pieces at a plumbing supply store. Split them down the length and hammer out flat. Clamp the pieces behind your weld as an extra heat sink, this will usually stop burn through.
For holes, you can take regular 1/16" / 1.5mm welding rod and coil the end to the size of the hole (like a coil of rope on a boat), tack it in place and let cool, then weld it up.
Old 03-05-2010, 08:18 AM
I would try using the newer panel bonding adhesives. No warpage, no fires, no blowing quarter sized holes in your sheetmetal. Easy peasy lemon squeezy.
Old 03-05-2010, 12:49 PM
Augusto's Avatar
Originally Posted by oldBodyman
Augusto,
I have 2mm (.078in) thick copper sheet, that will be better, thanks for the idea
for holes I use a 6011 electrode with the coating stripped off as filler rod, but your idea is pretty good as well.
New Hobart MIG welder Chris Kemp Garage - Tools 1 04-08-2009 12:36 AM
How big a bottle for MIG? rwruther Garage - Tools 11 08-14-2008 02:40 AM
~ MIG WELDING - The DIY Guide. Sanctifier Garage - Tools 4 04-23-2008 03:34 AM
Just got a Lincoln 100T MIG '32ROD Garage - Tools 6 09-04-2006 04:47 PM
mig welding richardson110 Body - Exterior 5 10-03-2004 08:17 PM
