I had alot of practice.But just keep playing with it,you will get it,If we lived closer,I could show you alot better.It also has a lot to do with setting the welder right.
I think Mikey hit the nail on the head with the gauge reading 0 but still had gas left. He just needs to learn to slow down and practice more. And make sure to never weld without gas.And like somebody else said,to have a steady hand to make a good weld you have to be in a comfortable position.
And try welding right to left and see if you do better.Point your wire where you want to weld not towards where you already welded.Hope you can understand, If not maybe NEW INTERIORS will post a pic of what I mean.
I point the gun towards the way I'm going,This also helps to blow the dust and what ever else is there out of the way.Let someone move your wire speed while you are welding,You will be able to tell where it is best.
Try and post us some pics,Then we can better help you.
gas
When I get my frame back I will grind off the paint and weld it up and take some pics but from what I gather from you guys all I have to do is.. do everything the exact opposite of what im doing I should be able to weld half ***...which is better than no *** at all.
If I can see a picture of your weld, I will know what you are doing wrong.If you can weld a little piece of scrap metal so we can see it.Me and some of the other guy's will be glad to help.
gas
Pickin up my tranny and rear tomrrow so I'll grab some gas ,run a bead and get the wife to take a pic.Never posted a pic here before so be patient and I'll get her done..Really appreciate the help guys.
No gas with solid wire wont even make a good tack
Shane |
mig gas
Here are the pics. Hope they work. I lost the .035 tip so I went to .023 wire. One of gauge settings,one of old way of welding, one of bottom of metal,one of new way of welding and one of settings on machine. O.K. what do you think. The new way of welding works pretty good. I welded the way you guys said. Just got to learn how to stay in the middle. Welded more on the bottom than on top. Oh well practice pratice practice.
Are you using 75/25 gas? The first pic,Look's like you may be a Little hot.Try when your welding to come in and out a little bit(not to much).not up and down.Try turning your wire down a Little too.If you turn it while you are welding,Turn it till you see the wire come out the puddle,Then turn it to where it is just burning in the puddle.You don't want it to burn deep into the puddle.You shouldn't have to wait for it to build up.You should be able to run with it.It would be better if I was there with you.Sorry.
| Recent Garage - Tools posts with photos |
| Mastercraft Mig welder? Canadians eh | montea | Garage - Tools | 19 | 01-23-2007 11:24 AM |
| 2 Gas related Questions | JIm Sam | Engine | 10 | 12-01-2006 04:24 PM |
| A little perspective on gas prices | Centerline | Hotrodders' Lounge | 24 | 05-23-2005 02:50 PM |
| AV gas | Chevy Thunder2 | Engine | 51 | 03-21-2004 12:26 PM |
| want cheaper gas prices?? plz read this | sherfield2002 | Hotrodders' Lounge | 7 | 03-12-2004 05:22 AM |
