MIG How long does sheilding gas - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2005, 03:03 PM
aminga's Avatar
Last journal entry: Cleaning and Powder coat
All,
Just purchased a new MIG machine and I was getting ready to buy a cylinder of Gas. I was considering using the 25 Cu Ft cylinders of C-25. How much life are you getting out of a cylinder of gas and how big is that cylinder?
Old 09-07-2005, 03:59 PM
modas's Avatar
Dazed and Confused
Last journal entry: Trunk Part 21
If you can, I would recommend a larger tank. 55-70 CUFT. I got the small tank thinking it would be plenty. Running at 25 CUFT /hr flow rate only gives you about an hour of actual welding time. Seems like a lot, but it really isn't. When I go get a refill, I'm upgrading to a 70 CUFT tank.
Old 09-08-2005, 02:02 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
It really depends on what you set the regualtor at. My welder doesn't require the gas to be turned up that high, but I am in a low airflow environment when I am welding(doors shut,no fans,etc) It also depends on if you forgot to turn off the regulator after every use, sometimes it will bleed off and drain the tank some. Also depends on how much you are planning on using it...everyday? weekends only?
Alot of variables that going into trying to guess how long it will last you.
Later,
WEIMER
Old 09-08-2005, 09:59 AM
Get the biggest tank practical for your situation, be very careful with your flow settings and be sure to turn off the tank. Some people simply wa$te a heck of a lot of their gas by being careless with it and over time C/25 can get quite costly if you waste it. A lot of gas is wa$ted by increasing the flow in an attempt to weld in drafty conditions thinking that will make up for the gas being blown away by the draft but in fact this helps very little. The problem with drafts is more of a shielding gas contamination problem from atmospheric gas than loss of shielding from the draft so controlled welding conditions is the answer and increasing flow usually just wastes gas. Another situation that leads to waste is increasing flow in an attempt to correct a problem such as porosity when the cause is something else such as dirt, rust or paint contamination so if you are having weld problems check for other things before reaching for that flow control and most of all determine how much gas you really need for your situation and don't use more than necessary. Remember if you need 20 cfh and you have a setting of 30 cfh you cutting your gas supply by 1/3.
Old 09-09-2005, 09:18 AM
aminga's Avatar
Thanks guys,
I realize the correct answer is "it depends" that's the answer for most questions in life. Since I'm about to go buy a bottle I choose the same philosopy as I did for the MIG. 110 would do for most of what I do but I took the 220V machine for the extra capacity.
Looks like I'll go find a 40CU ft cylinder that 20 at Tractor supply doesn't look like such a good deal any more.
Old 09-09-2005, 09:29 AM
Aminga, actually Tractor Supply is a very good place to get your gas and they should have any size tank you need in stock, at least the two here locally stock large tanks. Their prices are fair and most are open on Sunday which seems to be the most popular day to run out
Old 09-09-2005, 12:16 PM
Almost an old guy...
I went with a 40 and have been very happy with the time between refills. Since I got my MIG I have been welding quite a bit on a lot of projects and it seems to last a long time for me. The best tips are mentioned above. Set the regulator where it really needs to be and remember to turn it off when you are done, I'm a believer that more gas is wasted than used if you don't do those things, my neighbor uses twice as much gas as I do and welds half as much, most of the time because he forgets to close the valve at the end of the days welding.
Old 09-09-2005, 04:34 PM
aminga's Avatar
You're right. Turns out the sell 2 20 Cu ft cylinders. A weldmate brand, sold instore full and the gaspony. brand. The gaspony is a bit cheaper. Thanks.
Old 09-09-2005, 04:36 PM
aminga's Avatar
Each person uses their machine a different ammount. So here's a measure. How many 1LB units of welding wire does the 40 Cu Ft cylinder last.
Old 09-21-2005, 12:02 PM
Festive57's Avatar
Classic Car Lover
I would talk to your local welding supply store. When I bought my Mig, I called all over the place looking for the best deal. I settled on a recycling supply store called Grecco's here locally. I went down with the intent to purchase a 90cu. ft. bottle for around $100.00. While there the guy that was waiting on be suggested a 135cu. ft. bottle for $145.00. I said I'll never use that much, I don't weld that much. He agreed with me, with the exception of when I take the bottle back for a refill the 90cu. ft. bottle would cost $25.00, the 135cu. ft. bottle would cost $27.50. Big difference in refill cost. I felt that by paying more up front I would save in the back. You may also find this type of savings with the bottle size that you are looking at.
Bill
Old 09-21-2005, 02:16 PM
Festive, You have pointed out a very often overlooked reason to get the biggest bottle practical since the bigger the bottle the less cost per cubic foot of gas with the difference between refill cost on a small bottle and a big one being close to the same it makes the gas a LOT cheaper per cubic foot.
Old 09-22-2005, 11:59 AM
Festive57's Avatar
Classic Car Lover
Oldred, I guess maybe I did. It will take me forever to empty the 135cu. ft. bottle, but it will cost me only an extra $2.50 for the extended time period.
Gas Smell . .& not baked beans! TheBreeze Engine 2 02-09-2008 09:32 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 04:17 PM
Question about gas grade??whats best?? Robbie Engine 18 07-09-2004 11:59 PM
T-350 Long vs short shaft change zachscc Transmission - Rearend 2 01-21-2003 02:53 PM
priming for 1st start w/new gas tank required? bullheimer Engine 4 08-09-2002 08:05 AM
