MIG thick to thin? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2005, 10:33 AM
daimon1054's Avatar
MIG thick to thin?
I just filled a hole in a fender on a trailer for my brother. The problem I had was the fender was thicker than the metal I had so a small tack would not penetrate the fender any longer it would burn through the patch (again it's MIG). What I ended up doing was starting on the fender then running into the patch but it took a long time and I had a lot of bead to clean up and of course some warpage. On a trailer fender it was not that big a deal but I would like to figure out if there is a way to do it. Mostly just curious never know when the info will be handy.
Old 01-19-2005, 10:50 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Welding different thicknesses of metal is tough, no doubt about it. You can get to the point where you learn to 'aim' the arc toward the heavier metal and run a reasonable bead w/ OK penetration but it takes practice. But what in welding doesn't?!
Old 01-19-2005, 11:15 AM
memphisrain's Avatar
New Member
Willy's got it right.
You generally want to keep the heat more on the thicker metal's side, then kind of bring it over to the thinner stuff.
Old 01-19-2005, 12:55 PM
daimon1054's Avatar
Thanks I was trying to tip it to hold the heat on the thick side but was not getting it. I guess more practice is in order. I am not used to thin sheet.
