Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mig welder suggestions
Old 01-15-2004, 02:36 PM
daimon1054's Avatar
daimon1054 daimon1054 is offline
On you welder there will be a amp rating, not what it puts out but what it uses. Amp X Volts = Watts as long as you come in under you generator rating you will have enough power but you also need to check what the fuse is. Most 110 have 15 amp breakers but the 220v plug is also rated @ 20 to 30 amp for 110 volt use. Gearhead if you wire a plug for the twist lock you should be able to runf you welder.
