MIG Welding - 030 vs 035 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-07-2011, 02:50 PM
deadbodyman's Avatar
Wiki Edits: 11
It was the Egyptians that developed the first standardized measureing system.When they started building the pyramids they needed help from all over and everyone had a different way of measuring,like with a string with equally spaced knots but no one spaced them the same way until they all had too work together and get the same measure...
  #17 (permalink)
Old 09-07-2011, 02:53 PM
I think maybe we are about to get into trouble.
  #18 (permalink)
Old 09-07-2011, 02:56 PM
Wiki Edits: 11
.....Give us an inch.........
  #19 (permalink)
Old 09-07-2011, 05:44 PM
life is a temporary assignment
My measuring system that is always with me is a dollar bill... 6'' long.. 3'' folded in half.... It will Help you out when your some where's and you don't have a tape measure with you...
  #20 (permalink)
Old 09-07-2011, 05:54 PM
gow589's Avatar
the Clever Turn Signal
Originally Posted by NEW INTERIORS
Just keep in mind,, The bigger the wire, The hotter you need to run the machine..The smaller the wire, The lower you can run the machine...
The smaller wire is good on panel work... You can keep the heat down and still get penetration..
You shouldn't need no more then 0.30...
I only use 0.23 and 0.30 ...The 0.23 can weld the thicker metal also... Like someone said... It has a lot to do with the guy holding the gun.... And for the thicker metal's,, Always bevel grind both sides... So you can get 100% weld..
I would agree. I think hobbyist like myself don't always work with the best tools so we learn to do with what we have. What I see is a lot of people who weld professionally say you cannot weld thick metal with a 110v welder; I say they never had to.
I learned with my Hobart 110v welder...which is pretty bottom of the barrel welder, that it does not weld ....ANYTHING as good with .030 wire as it does with .024 wire. But it does do an outstanding job with .024 wire.
The point being the 110v welder does not handle .030 wire as well. I can not speak for a larger welder but I have learned to do some prety large jobs with the smaller wire.
The part that is missed is with larger wire, the weld is much quicker. With smaller wire the weld takes longer and the added heat makes up for the inadequacies of the wire; providing there is a good bevel and you are laying down a good amount of weld.
What I found is, with good bevels, taking time to lay down good rows of weld, smaller wire can be quite good.
Here is a set of blades which went to a mush hog on a very large tractor. My tractor is 54hp and the tractor which used these is 2x the size. Blades are 1/2" thick and they were used to clear several acres including the mowing down of 100's of locust trees. Notice the heat distortion. The area welded (not just the weld) was cherry red when I set the gun down:
This is a 1/2" thick tab on a very large water table. I had to torch it off for transport and weld it back on during set up. The tab was used to lift the table which is heavy enough to make a 5000lb fork truck light on it's wheels.
My neighbor pulled out a plow with no attachment bar. We welded on a 1" thick plow bar to the top; no mechanical advantage just weld. He plowed a couple acres in the back yard to feed the deer corn.
  #21 (permalink)
Old 09-07-2011, 06:32 PM
I have welded professionally from 1968 until I retired a few years ago and when I hear someone, especially a pro, say that a 110 welder can't be used on thick metal the first thing I think is "that's BS"! While there may be limits from a practical standpoint due to duty cycle, time spent doing the job, etc there really is no limit to how heavy a section that can be welded with .024 wire and a 110 machine. The trick is pre-heat! With small wire and low AMPs there can be serious problems when starting the weld on a heavy section because the thick metal will sink off the heat too fast and cause chilling of the bead leading to under-bead cracking from thermal shock, poor penatration and a brittle weld. That's where the mistaken belief these machines can't be used for heavier metal comes from but this is very simple to avoid. Just heat the area to around 400 deg or so, just too hot to touch with your bare hand, and then there is no problem. The inherent heat from the weld will eventually raise the temperature if no pre-heat is used but a lot of damage could occur before the metal becomes hot enough, the pre-heat will prevent this. An Oxy/Acetylene torch is useful for pre-heat but unless the part is really large even a small Propane torch is all that is necessary, 400 to 450 deg is plenty for starting the weld and that's a long way from red hot so those little torches are usually enough. In any case the pre-heating makes a world of difference when using low AMPs and small wire.
  #22 (permalink)
Old 09-08-2011, 06:17 PM
Elevinpointsixtoone's Avatar
Since there seems to be no "rule of thumb" no pun intended and I do have 210 amp 230 volt MIG I might as well pick up a roll of .035 and see how it runs. So far, my .030 tests look good up to eight inch while the 5/16" had a lot of weld bead fully wetted out on top but maybe only 50% penetration. I got good results on the 8th by turning the wire feed down from the recommended setting and welding slower. In fact, I started burning holes through the base material....so...I'm just now finding this machines sweet spot. I will grab a spool of .035 and see where that takes me.
Dave
Mig Welding 454 Rattler General Rodding Tech 3 10-20-2009 09:59 AM
Butt welding vs Spot welding 69ChevelleAddict Body - Exterior 19 05-04-2008 02:47 AM
welding on an oil pan? catfish hunter General Rodding Tech 13 02-01-2007 05:45 PM
gas welding txdrifter Body - Exterior 8 11-19-2005 09:30 AM
Welding xxx(madmax )xxx General Rodding Tech 4 03-01-2003 09:10 PM
