mig welding - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2004, 09:31 AM
mig welding
Hi I just bought a mig welder the gasless mig pak 10 from jegs. I've never welded with a mig before and I am having a hard time getting good penetrating welds that hold. I made some practice welds with the old floor pans that I cutout, I made sure I cleaned them off real good but my welds suck. I don't know what I am doing wrong I am ok at arc welding and I thought mig would be easier. Can anyone recommend any videos or cd roms that would help??
Old 10-03-2004, 10:15 AM
Rich-Need to know what your welds look like,are they burning thu? Are you sure the polarity of the machine is set right? If you are using gassless wire then it will be difficult to get a really good weld and you probably will never be completely satisfied until you bite the bullet and get some gas and MIG wire. Gassless welders are NOT MIG welders(Metal-Inert-Gas)no matter what some catalogs call them as there is no such thing as a gassless MIG and true MIG welders are light years ahead of gassless welders. Let us know a little more about your problem and I am sure that someone here can help.
Old 10-03-2004, 04:51 PM
The welds are pooling on the sheet metal and they are not very strong because they are not fully penetrating. When I lower or raise the feed speed its no better and if I raise the heat to the next level it just burns right through. I think your right I am going to have to bite the bullet and buy some gas. That's what the guys at work suggested. Thanks for your help.
Old 10-03-2004, 06:36 PM
daimon1054's Avatar
First turn the heat up till you burn though. On thicker stuff you need to slow the wire feed down on thinner speed it up and move faster. If you open the side cover almost all units have a recomended setting for voltage, wire speed is up to you. Turn the speed up till you feel the wire pushing you off the work, that is to fast, slow it down some then move slow. Flux core will weld just fine but it is like 6011 rods, easy but messy so look for a lot of splater.
I also find draggin the puddel and working in small circles is the best way for me, pushing does not give me enough penetration. The thinner the wire the deeper the penetration, yes it seams backwards but the smaller electrode concentrates the heat more. Last keep the distance short, if the wire gets long you will lose voltage, the electricity is introduced at the tip.
Old 10-03-2004, 07:46 PM
Daimon is right on,not much that I could add except to suggest that you practice on some scrap until you get the hang of it which I am sure you will in a short time. Flux core wire is just a little harder to use and not quite as clean but it will work.
Old 10-03-2004, 08:17 PM
suck, squeeze, bang, blow
Last journal entry: finally reeled it in
I hear you brother...
If one of the guys at work have a MIG with gas or you can try out a MIG with gas, do it. I've tried welding gasless a few times and have always had poor results. With sheet metal I would rather use a spot or tiny stick and arc weld instead of fluxcore MIG. With gas, it's like spreading on a weld, even a novice can make decent strong welds.
