I use a very fine sanding pad,And lightly hit it,When the machine is set right and the alum is clean right,You shouldn't have to pre heat it.You should only have to pre heat it if your machine isn't big enough.Don't be scared to run it a little hot.
I like to use these sanding disc.(But make sure it's a fine one)..
