Might paint my beater truck - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-29-2009, 02:58 PM
Wiki Edits: 31
Originally Posted by Irelands child
A quart should cover a fender and a door.
As far as PO ing folks here with Rustoleum/POR15 paint jobs and a roller - I recall at least 2 threads here that got folks' panties in a bunch
Dave W
I know of at least 4... But the ONLY reason I was even considering it was because the truck is just a beater anyway..
  #17 (permalink)
Old 04-29-2009, 03:24 PM
well, the restoreation shop has:
http://www.tcpglobal.com/restorationshop/rsp2304.aspx
for a 1-gallon kit that has everything, it's $84.95 isn't that less than $44/qt plus hardener ??
  #18 (permalink)
Old 04-29-2009, 03:31 PM
and since nobody likes to talk about Kirker when you talk about cheap paint, what about Transtar. Isn't Transtar a brand of clear used in many body shops??
http://www.levineautoparts.com/autopaint.html
  #19 (permalink)
Old 04-29-2009, 03:43 PM
Wiki Edits: 31
1/2 pint of hardner is $15.95.. so doing a quart with the original color would be just a bit cheaper...
  #20 (permalink)
Old 04-29-2009, 05:21 PM
What's wrong with Kirker? It's exactly what I would recommend for a cheapo job. I bought several different colors of their Ultra-Glo and I'm going to do some test shots in a week or two, and then shoot a butt ugly Isuzu Trooper with it.
http://www.kirkerautomotive.com/html...ID=103&SORT=79
And there's your color too.
If you just paint a couple of panels, it will never match.
  #21 (permalink)
Old 04-29-2009, 05:39 PM
i just did my galaxie with -tcpglobal-restaration shop- 88 dollars for the kit-- acrylic enamel -- sanded and buffed-- it lays down nice and looks good --
  #22 (permalink)
Old 04-29-2009, 06:58 PM
Pic's of the galaxie ?? I've often wondered about TCP paint. Anyone know what that really is? Omni or Prospray or Nason ??
  #23 (permalink)
Old 04-29-2009, 07:17 PM
Wiki Edits: 31
it's restoration shop brand paint. it's suppose to be good... the Auto color library ( TCP Global ) also sells PPG products
  #24 (permalink)
Old 04-29-2009, 07:52 PM
do a ebay search-- auto paint-- tcpglobal has both bc c and acrylic enamel-- the price is right --get the kit-
  #25 (permalink)
Old 04-30-2009, 04:02 PM
Wiki Edits: 31
Well, I keep getting low ball offers on the truck, so it looks like I'll probably end up keepinng it....
but if I do, I think I'm going to do some custom work to the cab and front fenders, and turn it into a model A looking truck... cut the front a and b pillars in the center at an angle, chop the rear of the cab a few inches ( 4 or so ), then lengthen the roof so the a and b posts would be completly vertical. fill in the rear window, and use a mail slot template, then reconstruct the cowl to resemble that of a 30's Cowl.. Model A grille and grillshelle, and a radiator that will fit... flatbed or I'll make a bed that looks right..... then I'll paint it a nice color
  #26 (permalink)
Old 04-30-2009, 04:50 PM
when you do -take lots of pics-- sounds like a fun project
  #27 (permalink)
Old 04-30-2009, 05:02 PM
Wiki Edits: 31
I will probably make a project Journal.. I'll probably have questions too
  #28 (permalink)
Old 04-30-2009, 09:23 PM
Valspar paint from Tractor Supply, Its ss auto paint that can be used with or without a hardener. Aound $27 a gallon. If you do try for the old style look you can use a dodge ram 94-02? for the cowl top.
Shane
  #29 (permalink)
Old 04-30-2009, 10:01 PM
Wiki Edits: 31
Shane
and to the junkyard I go shopping seems as that would be perfect for the cowl
  #30 (permalink)
Old 05-01-2009, 09:05 AM
oldcpecdr's Avatar
old school truck look
Anyone got any pics of a newer truck made to look "old school " , might be a fun project for a daily driver, I call on lots of Automotive business' and would be an attention getter for more sales...
paint information kimman Body - Exterior 13 06-02-2013 06:53 AM
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-22-2007 12:32 AM
replacement pickup truck - your advice please jojo99 Hotrodding Basics 7 05-03-2006 11:52 PM
how do i mix paint to spray a truck frame anthony herrera Body - Exterior 3 05-12-2003 06:43 AM
