Mighty Demon 850 no secondary squirt - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2007, 06:26 AM
opinionated old fart
Last journal entry: Sheetmetal
I have a new Mighty Demon 850 on my 496 and the truck developed a stumble on acceleration, have narrowed it down to no secondary pump shot. The diaphragm is good, the passage is clear and the umbrella valve is good. Any tips?
Larry
Old 06-25-2007, 08:58 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys - Out to Body and Paint
Wiki Edits: 2
I had the exact same thing with a brand new Mighty Demon. Remove the fuel bowl, and find the matching hole in the metering block that receives the fuel from the bowl. You can trace the passage in the block as it rises up and turns to the left (looking at the metering block from the fuel bowl side) and goes to the center of the block where it mates up to the holes in the main body. It is a raised, machined passage and easy to spot.
Right at the top of the passage there is 90 degree change in direction. At each corner of the passage, look for two tiny brass plugs threaded into the sides of the passage. These plugs were left out on my Demon, and without them the accelerator pump just pushed the fuel back into the bowl, and therefore no squirt...
It looks like the passage is drilled from both directions, and these plugs are needed to seal off the holes after drilling.
I called BG, told them the problem and they shipped me put a couple of plugs. After installing the plugs, the squirters worked fine.
This may or may not be your case, but it's a place to look. When you push down on the pump arm, does it compress, and seem like its pumping gas, or do you get resistance, like the gas has nowhere to go? Hope this helps,
Steve
Old 06-26-2007, 05:22 AM
When the pump is activated you can see turbulence in the fuel bowl and a little fuel dribbles out of the nozzles. I guess I will call BG tech support.
Larry
Old 06-26-2007, 06:37 AM
Technical Support Barry Grant
Larry
Larry,
If you're seeing turbulence in the bowl it could be what Steve392 mentioned about the blocks, or it could be the rene' valve in the bowl. It should prevent the fuel from coming back up from the pump housing when the accelerator pump is depressed. The valve may not be completely seated.
Old 06-26-2007, 09:02 PM
if you are talking about the umbrella valve, it is sealing. with the bowl off and the port blocked the accel pump holds pressure. how do I get the blocks for the passage?
Larry
Old 06-27-2007, 05:57 AM
Are the cross over plugs in the metering block?
BG Road Demon secondary squirter? Leevon Engine 1 05-25-2007 06:39 AM
850 Speed Demon too much??? hotrodf1 Engine 3 08-15-2006 08:04 AM
850 demon 347mustang Engine 4 08-08-2005 09:40 AM
De-blowerizing a Mighty Demon 850 Mad Maggot Engine 8 07-10-2005 01:10 PM
383 and Mighty Demon! camaro80 Engine 12 03-10-2005 05:29 AM
