Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mighty demon.BC carb ?
Old 01-18-2012, 07:55 AM
2fox 2fox is offline
Ok i got a.489 BBC with.8-71 TBS blower got 2x.750 blower carbs also from TBS. Just got motor.fired up i had no vacuum lines hook up to the carbs
these carbs are boost ref power vavles.i found the nipple that pulls vac.through the vavle are these suposed.to be tied together.into the back of the blower manifold?
With no vac lines.hooked.up..shouldnt it run rich.?.which i think it is
would this.make my headders glow.red at.about 2000/2500 rpms?
This is my first blower carbed engine.
And for my trans. Mod valve.run it.to a full vac source off the base plate...did i need.to tee.them together on both carbs to the mod vavle..thanks
