Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mighty demon.BC carb ?
Old 01-18-2012, 04:13 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Power valve vacuum source goes to the intake manifold plenum below the blower.
Preferably with a in line one way check valve to avoid boost pressure acting on the power valve diaphram(s).
Same with the trans vac modulator, to the intake manifold under the blower with a in line check valve. A mechanical (cable acted) trans modulator is another way to work the trans shift pressure. Get one from a GM desiel van w auto trans.
The Rich idle and hot header tubes is mostly caused by a lack of initial spark advance timing at idle. Roots supercharged motors need a lot of timing at idle.
You need to shorten the mechanical advance curve to allow this.
You need a 10DEG or less timing curve.
Fix the timing curve to allow this.
If the blower motor has a fair big cam just lock out the mechanical advance curve and set the locked timing at 28-30 deg BTDC. (street Blown on pump gas, without boost timing retard)
If you are using boost retard, set the locked timing at 36deg BTDC at idle and take 6 to 8deg timing out with the boost retard box, under boost WOT
A roots supercharged motor will idle much cleaner with a generous amount of spark advance at idle. The bigger the camshaft, the more timing it will like at idle. 26deg +++ @ idle
