In pic.#3.the.big.plig at the rear.of the.cars.am going.to run it to the.vac mod. Valve.correct?
i need.to lock oit the.dost.like.you said ?.is that to much.i thought more.like.22/26.with.pump gas i might.have less boost then planned on .i as.set.up for 12%ud.but.that.was.with.srock iron heads.i got.345.cc.ingake.runners now.TBS.I might.noy see 8psi.bit less pulleys.are.59 /58 upper and.52/54 lower cant rember.but.of i only.see.say 5/6 psi .i will the.swap the.pullehs.and.od.ot.13.5.% i thinllk.
Let me know.if.am.rigth.or not.thanks
