mighty demon to big - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2005, 09:09 PM
mighty demon to big
my cam specs are
valve lift is .575 intake and .575 exhaust
duration at 50 thousands is 300
lobe seperation is 110 at .050
357 chevrolet
about 11.5:1
victor jr heads
victor jr intake
Problem.
850 mighty demon
WIll I be able to get the motor to idle right with this carb and will the motor run right with this big carb.
What can I do besides getting a new carb or building a bigger motor to fix this problem? example, are there any mods I can do to the carb to make it work...
Old 02-15-2005, 10:16 PM
underdog305's Avatar
It sounds like you haven't tried it yet? I would suggest putting that 850 on and seeing what happens..
Old 02-16-2005, 06:39 AM
rick458's Avatar
Wookie
I would think a 750 would be lots better
but give it a shot, looks like it should rev with that cam, at least you have an Idle ease to help out
Rich
77 Impala
74 260Z (a Work in SLOW Progress)
69 Big Block Chevelle (long gone)
Semper Fi My Brothers
Old 02-16-2005, 06:43 AM
Last journal entry: PICTURE TEST
carb
If you have a 11.5;1 static and a cam with 300@.050 it will never idle no matter what carb you put on...
Keith
Old 02-16-2005, 09:43 AM
Ratoflic's Avatar
Big cubic inches small Chevy!
Too big
Like Rick, I will definetly go with the 750, there is the requirement for the 850:
Radical Street/Strip Mechanical Up to 260 Manual
Street Rods W/Annular Dual Plane, or or 3,000+ stall
850 425 - 540 Single Plane 18 to 20
There for the 750 Mighty demon:
Radical Street/Strip Mechanical Dual Plane, or Manual
Street Rods 355 - 477 Single Plane or 3,000+ stall
750 Up to 260 18 to 20
Or you can asked to BG tech and they absolutly answer your email with the right carb with the tech sheet to fill.
tech-sales@barrygrant.com
My 0.02 cents
Just for your info, I have a 750 mighty demon with a strong 468 CI...
Stephane
Chevy man forever!
Old 02-16-2005, 12:30 PM
demon
I already have the 850 on the car. I would prefer to not sale it, lose money and then have to buy another demon. If I have to then I will but I would prefer to get some ideas on how to make this one work decent.
Anybody have any idea of the hp differences I can expect from using my 850 mighty demon instead of getting the correct size carb.
Old 02-16-2005, 12:46 PM
Ratoflic's Avatar
Re: demon
-You can remove and play with the ''Jet'', it can be a solution!
Just my 2 cents
Stephane
Chevy man forever!
Old 02-26-2005, 11:22 AM
Technical Support Barry Grant
Running an 850 on an engine of this size will most likely result in a rich idle, poor acceleration, and possibly lean wide open throttle. A 750 would be a much better choice. You've most likely listed your advertised duration. 300 duration @ .050" for a cam of this size would not seem normal.
Old 02-26-2005, 07:24 PM
lluciano77's Avatar
That is what Ebay is for. You can sell it and keep most of its value, and then buy a the right one. I have tried out about 8 carbs on my engine this way. I usually end up breaking even, or just loosing the cost of shipping.
