Mighty Wiper motor assembly
About a year ago I installed a Mighty Wiper in (on?) my car and it made 3 wipes across the windshield and died with a puff of smoke. I pulled it and installed one of those common boat wiper motors that I had instead to register the car. Finally a couple days ago I decided to see what happened and it was an easy fix - cold solder joint that came apart. I hooked it up but really do NOT like the wiring arrangement - the motor is always electrically 12VDC 'hot'. You do not, without having a second kill switch, have any alternative to their wiring arrangement. Maybe I'm overly cautious, but in a vehicle like a fully home built street rod, feel that this can be a dangerous situation. The wires to this motor are no more then 22ga, with the lead supplied at only about 30-34 inches long so regardless of whatever you do, you have to splice some additional lengths to the supplied wire - and unless you solder that tiny wire, it sure wont hold in crimp connectors. These wiper motors seem to have a pretty good reputation and should have for their exorbitant price. This raises my question - has anyone here had any problems with these? Should I replace the supplied wire with something like 18ga - it would be easy to do?
Dave W |
The motor draws less than an amp so the supplied 22 gauge wire is mathematically sufficient, but I usually install a plug close to the motor and then run 16-18 gauge from there down to the switch, because I too tend to be overly cautious.
As much as I like to worry, I wouldn't worry about it. Hope this helps..... Joe G. |
Vince - as far as self parking, mine wont consistently either. I have to pull it off again to drill and pin the shaft in position as I had to shorten it to work clamped to a bracket on top of my windshield. The 'C' clip is lost when the shaft is shortened and in my haste forgot to finish the job. I'll also see if it will work on a single wire, hot only when the switch is flipped on. These things are $140 bucks now and when compared to the boat wipers, too much money. Dave W |
| Wiper motor | Rag top bird | Electrical | 3 | 05-06-2011 01:49 PM |
| bad gm wiper motor? | ckliever | Electrical | 8 | 09-22-2010 03:39 PM |
| S10 wiper motor | awoodman | Electrical | 4 | 12-20-2008 09:12 AM |
| Wiper Motor | Jude-Racer | General Rodding Tech | 3 | 09-29-2006 10:39 PM |
| wiper motor won't run | cboy | Electrical | 14 | 05-03-2006 09:44 AM |
