MII Alignment? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2009, 10:08 AM
S10xGN's Avatar
Gotta love a turbo!
MII Alignment?
Hi All,
I have a new RCM Mustang II front clip under my '72 Maverick that's been aligned by "eyeball". I just ordered this caster/camber gauge from Speedway Motors and I have the spec's to go by, but which do I do first, caster or camber? I know the toe gets set last...
Thanks!
Russ
Old 09-01-2009, 10:27 AM
302 Z28's Avatar
I don't know the answer, but I do know where you can get the front end set properly if he is still in business. The old Airport Gulf station across from the airport is where I took my 34. He did a great job and was really interested in my car. He is also a rodder.
Vince
Old 09-01-2009, 09:10 PM
Cape Cod Bob's Avatar
Camber first then caster then redo each till u are done. Seen on a vedeo , may be on this site but I am to tired to look. U must also check with wheels turned to see run out.
Old 09-02-2009, 02:38 PM
S10xGN's Avatar
Gotta love a turbo!
Vince
Should have asked you first! <LOL> I'm leery of anyone ruining my fit/finish and decided to do it myself (as usual).
Good, thanks! I figured there'd be some "back and forth" between those two until it becomes right for both. Hopefully the magnetic gauge will have enough "stick" to hold to my billet wheels!
Thanks!
Russ
Old 09-08-2009, 08:26 PM
S10xGN's Avatar
Gotta love a turbo!
Just wanted to post back with +++ results! I got the frontend aligned in about 2 hours (after spending the previous 3 hours setting the ride height). After some checking, it seems my RF corner was 1/2" low. On my Mustang II front clip (RCM), the coilovers need to be removed to get to the adjustable upper shock bracket bolts. After doing this 5 times (remove shock, adjust bracket, install shock, jack car, remove stands, jounce car, measure heights) over 3 hours, I finally got the heights right.
The gauge won't work with wheels on, so I had to measure the drop from the lower CA's to the floor and make some blocks to match. then jack the car and remove the wheels, then drop the car on the blocks so it's at ride height. Next, the dustcaps had to come off so the gauge would fit flush on the wheel. Now the actual alignment could be done. I ended up using +4 caster and -3/8 camber. This was pretty easy to do on 1 side, but harder to duplicate exactly on the other side. My setup has two slotted bolts per side and the A-arm nuts face up, so they're easy to get to.
Russ
Front end alignment: When is "close enough", enough? scrot Suspension - Brakes - Steering 4 08-29-2009 06:40 PM
MII Pre alignment? Cape Cod Bob Suspension - Brakes - Steering 6 02-28-2009 11:12 PM
convertible alignment wedges? gto_ron Body - Exterior 7 02-01-2009 07:07 AM
NEWBIES 1st POST 72 chevelle spindles MII 42CHEVCOUPE Suspension - Brakes - Steering 3 01-04-2008 08:49 PM
MII tie rod 46 chevy pickup Suspension - Brakes - Steering 4 01-31-2007 07:00 PM
