mild 454 build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-11-2012, 06:47 PM
Old & Furious
Originally Posted by 454k1500 View Post
I don't mind shifting. I'd rather be shifting then texting and crash I would prefer the manual to be honest. I just need to get a new transfer case now. And pedals
Lol understod i just figured i would mention it. Manual can make a truck a lot slower cause it takes a little longer to shift em usally. Nobody wants to get smoked by a saturn. If you got to run 3 gears before you move 30 feet its going to be slower than auto build up. Anyone thats ever driven a granny gear truck under stands.
But i fully understand if speed is not your goal which im sure its not. A manual can be real dam handy on the trail or pulling heavy load. Auto does seem to work against you when you are towing heavy loads or trying to crawl even small rocks with stockish truck.
Transfer case may be easy to score in you pull it junk yard just got to be willing to drop a few and get a good one or two. Spares are always good bigger your tire the more spares you should have on hand. But rebuilders snatch them up since they are easy to rebuild with good gears its bearings and seals. Which are simple to install. Also great time to install the best bearing you can get. Since the price difference is only a few bucks. From bottom line stock to top of the line super strong bearings is only 15 - 20 bucks usally.
  #17 (permalink)
Old 12-13-2012, 09:06 AM
Switching over to a 465 is not terribly difficult. Aligning the bell housing and adjusting the clutch may cause some headaches but once they are set your good to go.
I prefer to run a 2wd 465 and a divorced transfer case. It makes changing the clutch a whole lot easier and all of the 2wd's had 35 splines eliminating one of the few weak links. As for the transfer case you have the room for a divorced and having a divorced lets you have tons of options later on. The classic 205 has proven itself, is quite cheap, and is mildly upgradable. If your toque increases and your foot gets heavier you can easily step up to one of the more expensive divorced cases from atlas, scs, etc later on.
The best way I have found to make the switch is to head to your local pick and pull and find a truck with a v8 and sm465. A bell housing from a 350 will also mate to many 454's. I am covering my butt in case someone finds one that does not mate but I believe the bolt pattern is the same on all the v8 blocks. There are some BEEFY ones in some of the larger trucks like sidekicks with 454's that have a larger input shaft. While you can put upwards of 600lbs into these the lager input shaft limits your clutch choices. I drive fairy stupid(off road) and have yet to need one of the larger input 465's. The standard input shaft will stand up to a lot of abuse.
As for bell housing choices you have 2. They are either full or half that is not the technical term I know but works to describe them. The full bell housing can be found practically anywhere and almost all of them are aluminum. You can also buy a full one from next to any shop that deals with transmissions. It is really the way to go you will need the 153 tooth flywheel if you want to stick with stock ish parts.
The half bell housing lets you have a larger flywheel and larger clutch and is cast. Although I am sure some out there is making aluminum ones. The downside is that these are getting hard to find. If you see one off ebay or something good chance it is for a 420 not a 465. The piliot diameter ring is smaller on the sm420. It is 4.667" for the SM420 and 5.125" for the SM465 you can have the 420 bell housing machined to open it up. But I have never personally done it before. You also have to adapt a different slave cylinder mounting bracket as the half housing used a manual style linkage. It is a lot of hoops to jump through to get the larger clutch which is only 1/2 to 1" larger then the one used with the full bell housing.
The easiest approach is to find a truck with a 465 at your local pick and pull and pull everything. The bell housing, clutch, flywheel, slave, fork, bearing,(all the old parts inside the bell housing) also get the pedal, linkage, master, and hose. I have taken the aligning pins before out of a junk yard block and actually had them match up to my new block so if you can get them out easily that could not hurt.
Then align the bell housing. Here is just one of the many videos that will help:
Then take all those old parts down to your local parts store(when they are not busy) and get all new parts. Having the old parts will make it tons easier to order new or upgraded ones. If the clutch and flywheel look decent or new you can run them. I know I have before on dedicated trail rigs. But on something that will be used for daily driving it is just best to replace the clutch and resurface the flywheel now while everything is apart.
Oh and while your at the truck before it gets crushed get the vin and year and note if it is anything Wierd like a dually, 350, or bread truck. Not doing this may have you kicking yourself later. It also makes it easier to just say you want a clutch for a 87 Chevy 2500 5.7 then explaining to the kid what kind of clutch numbers you need. Although I would still look into cross referencing clutch numbers to make sure the kid is selling you the correct part insted of finding out back at the house.
  #18 (permalink)
Old 12-13-2012, 10:04 AM
I have not tried to mount a 465 directly up to the 4401. It would require some type of adapter and I try to avoid adapters like the plague. If you find a 4wd 465 it will most likely be mated to a 205 with a small adapter which is only a few inches shorter then if you went with a divorced setup.
I have a 69cj5 right now that I had a 465,dana18/20 hybrid case, twin sticked, tara low, with warn overdrive built for. I do not know what engine i want to use on it just yet.. The combination is super tight because that's what I needed with the short wheelbase. I put that project on hold to build a buggy which is rear engine383, 465, brownie(divorced), custom transfer case(divorced) to custom 2.5 tons. This will be super easy to work on with no adapters and I should not need to baby it like I will with the cj5.
Adapters severely limit your choices later on. If everything is not perfect that adapter is nothing more then a fancy piece of scrap. I am not saying do not try it. Do what works for you. Anything is possible with enough cash and knowledge tossed at it. I just like things simple(and cheap).
  #19 (permalink)
Old 12-14-2012, 08:46 AM
Yeah. I want to be as simple and cheap(while using the best parts I can get) I want to keep the price down as I'm still I'm college so I don't want to drop a small fortune into it. I just want a basic swap that can be upgraded when I want to down the road. When I get out of college I might get an efi system, but I'm not sure. As of now I'm going with a sm465. (The easiest tcase to match up) and still looking for a strong driveshaft.
  #20 (permalink)
Old 12-14-2012, 10:35 AM
mild 454 build
You could do a little work on the heads, clean up the bowls, smooth over the exhaust ports. Get a solid lift cam like the Comp Cams XS256S .527/.532 lift and 218/224 duration. This should give you about 550 lbs of torque.
  #21 (permalink)
Old 12-17-2012, 08:57 AM
I found this for $250
muncie sm465 4 speed transmission with granny first gear. np205 gear to gear transfer case and Chevy v8 bell housing.
Great for off road truck or mud truck very low geared and strong as hell.
$250 obo cash
Would that be desireable?
850 carb too much for my mild 454? diamond mike Engine 6 03-23-2010 11:40 PM
Experience with mild 454 with NOS kahl_454 Engine 11 01-19-2010 02:30 PM
Power estimate of mild/stock 454 kahl_454 Engine 15 01-05-2010 01:52 AM
Building a mild 454 sierra4x4 Engine 2 11-08-2009 08:46 PM
mild cam for a 454 boss350 Engine 4 11-23-2006 06:19 PM
