mild bbc build for 4x4.? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2013, 04:33 AM
about to break down 454 on a budget looking for low end torq. any suggestions: cams, heads(prolly peanut ports/oval), pistons, compression,ignitions, anything would help. P.S. its a 70 blazer with 12in lift dana 60 14 bolt matching 456 gears and 38in boggers. also tranny info is good TH400.? im very open for ideas and need knowledge before i start thanks.
Old 02-13-2013, 05:04 AM
Use around 8.75:1 cr. Hyper pistons, 1/8 dome on the 120cc heads
120cc heads: 781 049 or 112cc head: 820 heads
Full length headers are very important for torque on a bbc.
A summit cam in the 210 to 212 degree range (at 0.050) on the intake with 110 lsa
I like the regular rpm intake with a holley 3310. But the stock intake will make more power under 3000.
Set up the mains and rod bearing clearance at 0.0015 to 0.0020 and the rear main at 0.0025-0.0030. BBC's require tight clearances to maintain oil pressure at idle.
Ignition timing: 15 initial and 40 total, then add another 10 degrees from an adjustable vacuum advance canister connected to a manifold source. So it will idle at 25 (15 + 10).
Should make 400 hp and 500 ftlb of torque and idle smoothly.
Old 02-13-2013, 07:38 AM
Thanks a bunch ill take that into consideration.
Old 02-13-2013, 08:19 AM
vinniekq2's Avatar
I bought a 1980 Camaro from a guy that built a 454 LS-5 for it.It had a .500 lift hydraulic flat tappet,performer and a quadra-jet with hooker headers.very similar to what 454c10 described.
It was a tire melter and made power to about 5,000 rpm.
It was fine as it was,but I had to improve it later,,,,,,,
mild 454 build 454k1500 Engine 15 12-17-2012 08:57 AM
Mild build on my 5.3 truck fschevy Engine 0 07-16-2011 05:29 PM
262 Mild build.. Need Help!! Matt262Blaze Engine 7 03-15-2011 07:37 AM
Help on mild 350 build.. Meangreen Engine 14 08-26-2009 07:16 AM
Mild 350 build... need help 350cruiser Engine 32 04-07-2009 09:29 AM
